Need help in complie synopsys library in Library compiler
venkat25
Junior Member level 2
Hi Friends,
I need to compile my synopsys library in Library compiler and check for the error in that like.
Is there anyone who knows library compiler well and could you guide me in compile my
library and synthesis it with the RTL code(VHDL or Verilog).
Thanks & Regds
Venkat
Re: Need help in complie synopsys library in Library compile
Hi Venkat,
I think what you need to do to compile your library is just read the library using read_lib command and write out a .db file using write_db command.
-Prasad.
    venkat25
