In a layout, I put both NW and NWH over a 5V PMOS, as follows
Could someone please tell me what it affects?THX
The circuit shown as follows, in the test, if the IN is high, the output is high, but if the INis low, the output turns to high from low afer 58ms, and there are signs that a large current about 1mA produced between VDD and VSS, thus we suppose the overlap of NW and NWH change the function of the PMOS, but we don't know how it works
I'm also using the smic18pf now. As his picture shown, it isn't disobey the design rule of the smic18pf. And i know the difference between the NW and NWH. So i just confused about the NW in the NWH. Although we don't draw the layout like this, if we do like this it is allowed. And the NWH is deeper than the NW, so the tolerance of the voltage isn't changed (still 5V). Am i right? By the way, the NWH is made before the NW from the mask ID.
But, if there is a break down, where it is? Because VDD is high, so the operational environment of the PMOS is ensured. If the gate is low, source is high, body is high, how could my drain become low, it makes us confused.
Maybe the truth is more complicate than break down, we suppose, thanks for your reply
---------- Post added at 08:50 ---------- Previous post was at 08:40 ----------
Although it isn't disobey the design rule, but it is unreason indeed, and it may cause complex results that we cannot deduce it in a normal way, i think
I don't think so: The breakdown voltage of the NW implant may already be close to 5V (ND ≈ 5e17). If another NWH implant is superimposed on the NW implant, both doping concentrations are added, hence the breakdown voltage will be even lower.
Between the superimposed NWH + NW and the substrate. With both implants superimposed you'll get into an impurity concentration range (5e17 .. 1e18) where the zener breakdown (as you mentioned above) already surmounts the avalanche breakdown (VB ≦ 5V).
I know your meanings. The tolerance voltage of the PN junction has relation with the doping concentrations of the P and N. But i meant the doping concentrations of the P and N near by the depletion layer is still the NWH and P-sub. How about the tolerance voltage of this PN junction?
... i meant the doping concentrations of the P and N near by the depletion layer is still the NWH and P-sub. How about the tolerance voltage of this PN junction?
if you superimpose two or more implants (or diffusions) over each other, you'll have a larger impurity concentration than from a single implant -- at any depth (s. the plot below).
I.e. the breakdown voltage of the junction (in whatever depth the crossing of the implant and substrate impurity concentrations may occur) will always be lower than if there were only a single implant|diffusion.
