my flip-flop does not change state between 1.2 V and 0 V
mohamis288
Full Member level 3
I have created a flip-flop using the following structure:
it is my flip-flop testbench circuit:
I have simulated this circuit and here is output result:
it seems it wants to change, but it can not. what is the problem do you think?
I have tested Nand3 lonely in schematic and it works correctly. here is the testbench for simulation of NAND3 and output result of NAND3:
That is a latch (at best, if wired right). A flip-flop has master and
slave latches.
Crack open any '80s RCA CMOS databook and find schematics.
Here is the link to this flip flop:
I just used this
Then this is a lesson about believing things you find on the Internet.
As is far too common "the exercise is left..."
Begin with some reading on latches / half-latches / flip-flops and the
classic forms (these days nobody makes D FFs out of NAND gates
and hardly anyone uses a JK unless they are doing custom transistor
level, primitive gate level bottom-up).
LaTeX Commands Quick-Menu:
