sudarshann
Junior Member level 2
Hi Friends,
I have the following doubts regarding interfacing multiple sim cards with a single sim300 module.
As you know sim card has the following pins
1 Vcc
2 Reset
3 CLK
4 Gnd
5 Vpp (not used)
6 I/O
In my case I need to use 32 sim cards with a single SIM300. Meaning only one sim out of 32 will be active. and active sim is decided by the mcu controlling the system.
The doubt i have is how can connect all the sim cards to same sim300. Can I do the below methods
1) tie vcc, reset, gnd, IO together and connect the clock signal of the required sim to the sim 300
2) I need a active sim indicator. to which line can i connect an led (smd) for indication.
Please provide me a solution for this issue.
Thanks in advance
1 Vcc
2 Reset
3 CLK
4 Gnd
5 Vpp (not used)
6 I/O
Thanks in advance
