I have designed a folded cascode opamp in which i'am using transistors of W=400um,l=1um; w=313um, l=1um; w=278um,l=1um.....
If i need to draw the layout of these transistors say of width w=400um and length l=1um as multifingers, how many fingers can i use....
can i use
(i) w=20 um and 20 fingers for w=400um for a channel length of 1um
(ii) w=39um and 8 fingers for w=313um for L=1um
(iii) w=28um and 10 fingers for w=278um and L=1um....
One more doubt is
Since my length is 1um and i'am using a lambda value(in layout) as 0.25 for 0.35um process technology, my length can be scaled to 4 units in grid.... min. width for polysilicon layer is 2 lambda.... so for a length of 1um, i could use only 2 fingers.... each of 2 lambda units making 4 lambda, so when i extracted in spice, i got the correct w/l ratio....
is my thinking correct...
or is there no relation between the length and the fingers.....
Please help.....Thanks in advance
