[moved] Shift Register and Serial-In Parallel Out converter
mwb
Junior Member level 1
Im taping out a chip that requires a robust serial-to-parallel converter. What is posted below seems to synthesize correctly but I have the following questions:
I use asynchronous resets because there are two clocks, p_clk and clk. clk shifts in the serial data, p_clk latches it out.
Async. resets obviously gives better timing and since I control the data-in, reset, p_clk and clk from off-chip, I don't think I will have problems with reset-recovery timing. I have to admit, reset-recovery time is a new concept to me, I mainly work on FPGA's and this is never an issue since the tools take that worry away. In this case, Im on my own synthesizing with standard cells and DC-shell.
Lastly, the shift-reg input:
        sr(data_width - 1 downto 0) <= sr(data_width - 2 downto 0) & serial_data_in;
        vec_mod_slow_in             <= sr;
looks like it might function more reliably if I reversed the order so that the output register vec_mod_slow_in is always defined since the synthesis tool does not support initial values:
The circuit synthesizes and functions perfectly. There is a two clk period lag before I can latch the data into the slow_registers but this is fine. It seems to improve timing, not exactly sure why.
I'd just like some opinions on this if anyone has any.
Thanks.
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.STD_LOGIC_UNSIGNED.all;
use work.mwb.all;
entity WVFRM_GEN is
  generic (
    data_width : integer := 68;
    bank_width : integer := 17;
    num_banks  : integer := 4
  port (
    clk             : in  std_logic;
    p_clk           : in  std_logic;
    serial_data_in  : in  std_logic;
    reset           : in  std_logic;
    serial_data_out : out std_logic;
    vm_a_en     : out std_logic_vector(11 downto 0);
    vm_a_en_bar : out std_logic_vector(11 downto 0);
    vm_b_en     : out std_logic_vector(11 downto 0);
    vm_b_en_bar : out std_logic_vector(11 downto 0);
    vm_c_en     : out std_logic_vector(11 downto 0);
    vm_c_en_bar : out std_logic_vector(11 downto 0);
    vm_d_en     : out std_logic_vector(11 downto 0);
    vm_d_en_bar : out std_logic_vector(11 downto 0);
    vm_a_s_i            : out std_logic;
    vm_a_s_i_bar        : out std_logic;
    vm_b_s_i            : out std_logic;
    vm_b_s_i_bar        : out std_logic;
    vm_c_s_i            : out std_logic;
    vm_c_s_i_bar        : out std_logic;
    vm_d_s_i            : out std_logic;
    vm_d_s_i_bar        : out std_logic;
    vm_a_sign_i_lsb     : out std_logic;
    vm_a_sign_i_lsb_bar : out std_logic;
    vm_b_sign_i_lsb     : out std_logic;
    vm_b_sign_i_lsb_bar : out std_logic;
    vm_c_sign_i_lsb     : out std_logic;
    vm_c_sign_i_lsb_bar : out std_logic;
    vm_d_sign_i_lsb     : out std_logic;
    vm_d_sign_i_lsb_bar : out std_logic;
    vm_a_s_q            : out std_logic;
    vm_a_s_q_bar        : out std_logic;
    vm_b_s_q            : out std_logic;
    vm_b_s_q_bar        : out std_logic;
    vm_c_s_q            : out std_logic;
    vm_c_s_q_bar        : out std_logic;
    vm_d_s_q            : out std_logic;
    vm_d_s_q_bar        : out std_logic;
    vm_a_sign_q_lsb     : out std_logic;
    vm_a_sign_q_lsb_bar : out std_logic;
    vm_b_sign_q_lsb     : out std_logic;
    vm_b_sign_q_lsb_bar : out std_logic;
    vm_c_sign_q_lsb     : out std_logic;
    vm_c_sign_q_lsb_bar : out std_logic;
    vm_d_sign_q_lsb     : out std_logic;
    vm_d_sign_q_lsb_bar : out std_logic;
    vm_a_sign_msb     : out std_logic;
    vm_a_sign_msb_bar : out std_logic;
    vm_b_sign_msb     : out std_logic;
    vm_b_sign_msb_bar : out std_logic;
    vm_c_sign_msb     : out std_logic;
    vm_c_sign_msb_bar : out std_logic;
    vm_d_sign_msb     : out std_logic;
    vm_d_sign_msb_bar : out std_logic
end entity WVFRM_GEN;
architecture behavioral of WVFRM_GEN is
  signal sr         : std_logic_vector(data_width - 1 downto 0) := (others => '0');
  signal serial_out : std_logic                                 := '0';
  signal vec_mod_slow_in : std_logic_vector(data_width - 1 downto 0) := (others => '0');
  signal parallel_out    : std_logic_vector(data_width - 1 downto 0) := (others => '0');
  signal vec_mod_out_reclk_1        : std_logic_vector(data_width - 1 downto 0) := (others => '0');
  signal vec_mod_out_reclk_2        : std_logic_vector(data_width - 1 downto 0) := (others => '0');
  signal vec_mod_out_reclk_post_mux : std_logic_vector(data_width - 1 downto 0) := (others => '0');  -- <[comment]>
-- signal test_pattern : std_logic_vector(data_width - 1 downto 0) := "11110000101000001011000011000000011101100101010000110010000100001001";  -- test pattern
begin  -- behavioral
  --- vec_mod_out_reclk_post_mux <= vec_mod_out_reclk_2 when output_enable = '1' else test_pattern;
  vm_a_en     <= vec_mod_out_reclk_2(67 downto 56);
  vm_a_en_bar <= not vec_mod_out_reclk_2(67 downto 56);
  vm_b_en     <= vec_mod_out_reclk_2(50 downto 39);
  vm_b_en_bar <= not vec_mod_out_reclk_2(50 downto 39);
  vm_c_en     <= vec_mod_out_reclk_2(33 downto 22);
  vm_c_en_bar <= not vec_mod_out_reclk_2(33 downto 22);
  vm_d_en     <= vec_mod_out_reclk_2(16 downto 5);
  vm_d_en_bar <= not vec_mod_out_reclk_2(16 downto 5);
  vm_a_s_i     <= vec_mod_out_reclk_2(55);
  vm_a_s_i_bar <= not vec_mod_out_reclk_2(55);
  vm_b_s_i     <= vec_mod_out_reclk_2(38);
  vm_b_s_i_bar <= not vec_mod_out_reclk_2(38);
  vm_c_s_i     <= vec_mod_out_reclk_2(21);
  vm_c_s_i_bar <= not vec_mod_out_reclk_2(21);
  vm_d_s_i     <= vec_mod_out_reclk_2(4);
  vm_d_s_i_bar <= not vec_mod_out_reclk_2(4);
  vm_a_sign_i_lsb     <= vec_mod_out_reclk_2(54);
  vm_a_sign_i_lsb_bar <= not vec_mod_out_reclk_2(54);
  vm_b_sign_i_lsb     <= vec_mod_out_reclk_2(37);
  vm_b_sign_i_lsb_bar <= not vec_mod_out_reclk_2(37);
  vm_c_sign_i_lsb     <= vec_mod_out_reclk_2(20);
  vm_c_sign_i_lsb_bar <= not vec_mod_out_reclk_2(20);
  vm_d_sign_i_lsb     <= vec_mod_out_reclk_2(3);
  vm_d_sign_i_lsb_bar <= not vec_mod_out_reclk_2(3);
  vm_a_s_q     <= vec_mod_out_reclk_2(53);
  vm_a_s_q_bar <= not vec_mod_out_reclk_2(53);
  vm_b_s_q     <= vec_mod_out_reclk_2(36);
  vm_b_s_q_bar <= not vec_mod_out_reclk_2(36);
  vm_c_s_q     <= vec_mod_out_reclk_2(19);
  vm_c_s_q_bar <= not vec_mod_out_reclk_2(19);
  vm_d_s_q     <= vec_mod_out_reclk_2(2);
  vm_d_s_q_bar <= not vec_mod_out_reclk_2(2);
  vm_a_sign_q_lsb     <= vec_mod_out_reclk_2(52);
  vm_a_sign_q_lsb_bar <= not vec_mod_out_reclk_2(52);
  vm_b_sign_q_lsb     <= vec_mod_out_reclk_2(35);
  vm_b_sign_q_lsb_bar <= not vec_mod_out_reclk_2(35);
  vm_c_sign_q_lsb     <= vec_mod_out_reclk_2(18);
  vm_c_sign_q_lsb_bar <= not vec_mod_out_reclk_2(18);
  vm_d_sign_q_lsb     <= vec_mod_out_reclk_2(1);
  vm_d_sign_q_lsb_bar <= not vec_mod_out_reclk_2(1);
  vm_a_sign_msb     <= vec_mod_out_reclk_2(51);
  vm_a_sign_msb_bar <= not vec_mod_out_reclk_2(51);
  vm_b_sign_msb     <= vec_mod_out_reclk_2(34);
  vm_b_sign_msb_bar <= not vec_mod_out_reclk_2(34);
  vm_c_sign_msb     <= vec_mod_out_reclk_2(17);
  vm_c_sign_msb_bar <= not vec_mod_out_reclk_2(17);
  vm_d_sign_msb     <= vec_mod_out_reclk_2(0);
  vm_d_sign_msb_bar <= not vec_mod_out_reclk_2(0);
  dff_1 : process(p_clk, reset)
  begin
    if reset = '0' then
      if rising_edge(p_clk) then
        vec_mod_out_reclk_1 <= vec_mod_slow_in;
      end if;
    else
      vec_mod_out_reclk_1 <= (others => '0');
    end if;
  end process dff_1;
  dff_2 : process(p_clk, reset)
  begin
    if reset = '0' then
        vec_mod_out_reclk_2 <= vec_mod_out_reclk_1;
      end if;
    else
      vec_mod_out_reclk_2 <= (others => '0');
    end if;
  end process dff_2;
--vec_mod_out <= vec_mod_out_reclk_2;
--vec_mod_out_bar <= not vec_mod_out_reclk_2;
  --fast_latch : process(clk, reset)
  --begin
  --  if reset = '0' then
  --    -- need to double check these states and possible double-dff for the crossing clock domains.
  --    if rising_edge(clk) then
  --      vec_mod_slow_in <=
  --    end if;
  --  else
  --    vec_mod_slow_in <= (others => '0');
  --  end if;
  --end process fast_latch;
  serial_data_out <= serial_out;
    serial_out <= sr(data_width - 1);
  process(clk, reset)
  begin
    if reset = '0' then
      end if;
    else
      sr(data_width - 1 downto 0) <= (others => '0');
    end if;
  end process;
end behavioral;
ads-ee
Super Moderator
Staff member
USA
Re: Shift Register and Serial-In Parallel Out converter
You don't seem to have a good grasp of VHDL if you think that switching the order of vec_mod_slow_in and sr is going to result in different circuits...It won't.
