tzg6sa
Member level 2
Hi All,
I tried to find the equations describe the temperature dependence of a MOS diode. Could one of you write me or send a link?
For a fixed current the voltage drop depends on the temperature. The voltage change depends on the overdrive voltage too, with other words the overdrive voltage has a temperature coefficient. The effective temperature coefficient is the weighted sum of the threshold voltage's and the overdrive voltage's temperature coefficient.
If we consider the quadratic equation, than it is the change of mobility with temperature. I am looking for its (basic) modeling.
