Missing connection from ModGen in Cadence Virtuoso
Junus2012
Advanced Member level 5
Italy
Dear friends,
I started to work with ModGen to implement circuit layout, the tools is really healpful and can save a lot of time to implement complicated matched array,
I started the test with simple two transistors pairs as shown below, I followed all the steps from Cadence to generate the layout model, but unfortunately when it comes it has missing connections, for example the connection to the gates or to the upper source transistors are missing, although Cadence is recognizing the connection
Do you have please an idea about such problem
Attached screen shots showing lack of connections so tool is right it is missing. I missing your point. What is the issue?
Dear Dominik
Thank you for your reply
if you see the schematic, gates are connected to vin+ and vin-, but the ModGen didn't connect it !! also the sources of the upper array is not connected.
So my issue is that ModGen is missing some of the connections from the schematic
