Microstrip patch antenna
munnalk
hello all,
i am a B.E 3rd yr student who is stuck with a prof who doesn't know much however i hav to do design n simulate a microstrip patch antenna on Ie3d.I feel a little helpless and would really appreciate if somebody could answer the following Qs
1)Is Ie3d the correct software to design n simulate a microstrip patch antenna?
2)All I know are the basics of antennas so how n where do i start?
Please go to www.zeland.com. There is a Zeland Virtual Training there. Regards.
sure IE3D is good software. I have seen people used it in Patch antenna design.
Some tutorial on zeland.com are provided. go through them as suggested by jian.
Also On this forum search some tutorial on patch antenna in HFSS.
Though software is different you will get an idea.
Also see this tutorial for reference.
This will help a lot.
Best of luck
Just try search feature .....
There are many tutirials in this forum abt patch antenna ..
Study some books .. Like Bahkl nad bhatia : microstrip antenna design ,, It will clear concept..
I worked on Ansoft designer
You may try that
hi,
you can refer to Microwave engineering Book by POZAR, Second or third edition - you will get the complete knowledge of microstips. then start simulations.
you can simulate it using ADS, but 2D/2.5Dmomentum only or else use HFSS. Search the "HFSS Tutorial" in this forum you will get microstrip antennna
Hi all,
want to design a patch feed for S band reception..
can someone provide design steps and photographs??
thankz
Hi...
If your antenna design involves a planar structure and more BW, better to use Flomerics' MICROSTRIPES 7.0.
I worked in Ansoft HFSS and other em s/w's... The choice of s/w depends on the type of antenna to design.
Books :
As someone mentioned.. pozar is must and more knowledge u can get it in Broadband MS antennas by IJ Bahl etc.
One more great book u can refer is Microstrip antennas by T.C Edwards (includes the practical way of implementation)
aditya[/b]
All these softwares require licenses, so use whichever available to you. Microstrip antenna is fairly simple to simulate so shouldn't be a problem. All the required information is within the forum.Best of luck.
hi,
this may be useful for u
  • simulation_of_a_2.4_ghz_patch_antenna_using_ie3d_8106.pdf
