Microcontroller malfunction in industrial environment
abc_de
Full Member level 5
Ludhiana ਪੰਜਾਬ
Hi ..
My microcontroller has stopped working and has gotten out of order while using in harsh industrial environment. i am driving circuit by +24v SMPS (OMRON) and using Line filter (COMMON MODE CHOCK) for 220v.
in circuit i have use decoupling caps .1uf with each IC and 10uf Bypass caps.
please guide me how i can avoid this problem
Please post your Schismatics
Reactions: abc_de
    abc_de
The improvement of your design should be done in two separate directions:
1. Hardware improvements - to minimize the impact of external noises to the controller:
- better schematic
- better PCB design
- better mechanical design
2. Firmware improvements. Whatever you do you could never guarantee that the controller will never hang or misbehave but you could do many improvements to minimize the impact of such events or even to make them completely invisible:
- watch dog and brown out detection are "must have"
- thread counters placed on many critical places to guarantee the correct sequence of execution. If threard counter is incorrect - start recovering preferably by doing hardware reset.
- make additional copies of the critical variables in your code and do special processing
- special software architecture to recover immediately and to make the misbehaviour minimal in time
In our company we struggled a lot with such noises, it came out that by doing 1 and 2 you could virtually make the design free of hanging. Even if it's affected from the noises this will be invisible for the user.
Kind regards,
Luben
Reactions: abc_de
    abc_de
And watch out for ground current loops
I once had a robot try to eat someone alive just because they had
connected the shielding of a simple rs232 cable to ground at both ends
instead of just one end.
Reactions: abc_de
    abc_de
Please view the schematic for more improvements
Utilizing embedded microcontrollers for industrial applications requires special attention given the harsh
and noisy environment. Going from a supply voltage as low as +1.5V or +3.3V to the +24V industrial world
requires careful design decisions and dedicated solutions to achieve safe and reliable operation.
First read this links
https://www.ichaus.biz/upload/pdf/WP1en_MCU Interface to Industrial World_08082012.pdf
https://www.ichaus.biz/appnote_industrial
Reactions: abc_de
    abc_de
Opto isolation is meaningless if both sides share the same power supply...
On the other hand, you don't necessarily need isolation to block interferences. It's more a matter of suitable power and ground layout, supply bypassing, transient suppression at supply lines and external in- and outputs.
Reactions: abc_de
    abc_de
I would disagree for opto isolation - it's proved to be the best and most reliable way to prevent the noises to come in. For sure it it would be much better if they are galvanically isolated but even with the current schematic it will be achieved significant noise immunity improvement.
Unfortunately it's not only about schematic - a good schematic with bad PCB rooting can compromise the noise performance. There is an endless list of tips and tricks how to make one PCB more noise immune. If you post the PCB design we could highlight some weak places.
Kind regards,
Luben
please also guide how to develop good firmware for robust, noisy environment
Since I mentioned rs232 I should perhaps point out it isnt a good idea to use it in noisy environments or on long runs
and of course I also mentioned current loops - but that phrase does have another use - the answer to not using rs232 -
I'd recommend having a read here : https://en.wikipedia.org/wiki/Current_loop to start with.
Reactions: abc_de
    abc_de
As previously mentioned, power and ground layout is the key. It's effectively impossible to make a transient resistant design on a single side PCB.
You need to connect the GND of the processor unit to only one point to the other ground wires in order to avoid currents flowing through these lines. The best way top achieve this is to redraw the schematic by using two different grounds (GND1 and GND2 for example). GND1 is only serving the processor where GND2 is for the other part. Between GND1 and GND2 you place a small resistor and this will guarantee that you connect them in a single point.
The main potential problem is to have currents flowing through the ground lines which can compromise the processor stability. Also as I said you need to remake the firmware and to put some features that prevents the processor form hanging. Don't forget BOD to be ON.
Kind regards,
Luben
