disabling timing checks selectively
Refer to the Synopsys Solvnet article
https://solvnet.synopsys.com/retrieve/022278.html
Control Timings in VCS
VCS/VCSMX can disable module path delays as well as timing checks at various levels of granularity viz. on the entire design, on a specific module or on a specific timing arc in a specific instance.
1. Disabling delays and timing checks on the entire design. Use the following compile-time options
+nospecify
This suppresses the module path delays and timing checks in specify blocks.
+notimingcheck
This suppresses the timing checks in specify blocks.
2. Disabling delays and timing checks per module or instance basis
You can disable timing annotation selectively by using the configuration file
that is passed to vcs command line via +optconfigfile
Syntax :
+optconfigfile+<configFileName>
Syntax for the configuration file
module {list_of_module_identifiers} {list_of_attributes};
or
instance {list_of_hierarchical_names} {list_of_attributes};
where:
The module is the keyword that specifies that the attributes in this statement
apply to all the instances of the modules in the list, specified by the module
identifier.
list_of_module_identifiers is a comma-separated list of module identifiers
enclosed in curly braces: { }
list_of_attributes is a comma-separated list of timing related attributes
The instance is a keyword that specifies that the attributes in this statement
apply to the particular instance specified by the hierarchical name.
list_hierarchical_names is a comma-separated list of hierarchical names of
module instances and signals enclosed in curly braces: { }
The list of valid attributes for timing is as follows:
noIopath : Attribute keyword that specifies disabling the module path delays
in the specified module instances.
noSpecify : Attribute keyword that specifies disabling the specify blocks in
noTiming : Attribute keyword that specifies disabling the timing checks in
3. Disable timing checks at runtime at ucli prompt
To get to the ucli prompt at runtime you need to compile the design with
-debug or -debug_pp at compile-time. At ucli prompt, specify the following
command:
tcheck <instance|port> <tcheck_type> <-msg|-xgen> [-enable|-disable] [-r]
where
<instance|port> is a hierarchical full path name of an instance or an
instance_port
<tcheck_type> is one of
[all|HOLD|SETUP|SETUPHOLD|WIDTH|RECOVERY|REMOVAL|RECREM|PERIOD|SKEW]
<-msg | -xgen> Optionally controls simulation behavior when a timing check
violation is detected as follows:
-msg disables or enables a timing violation warning on the specified instance
or port -xgen disables or enables a notifier toggling on the specified instance or
port
[-r] Optionally changes all timing checks for the specified instance and
all sub-instances recursively
