Mentor Graphics EE7.9 Library Manager PROBLEM
serterius_ing
Newbie level 1
Hello everyone and congratulations for the forum,
I'm just using Mentor Graphics EE7.9 in Windows 7 Ultimate. My problem concerns the use of Library Manager. After recording my access database fine "Data Sources (ODBC)" in :
Library Manager -> Edit Configuration DxDatabook -> Add Table -> New -> Data Source Manager appears correctly the alias of my database (ODBC). The problem is that when I click on Apply and then OK in the Add table the combo box "DSN Data Source" is empty.
Please help me ... :? :? :?
Have you tried using the Wizzard to setup your environment.
Procedure
1. In the DxDataBook window, right-click to display the DxDataBook menu.
2. Select Configure > New to display the New Configuration dialog box.
3. In the New Configuration dialog box, select the I would like to use the Library Wizard
to set up DxDataBook option and click OK to start the Library Wizard.
All this and a lot more can be found in the DxDataBook User's guide
  • dxdb_user.pdf
Procedure
Thank you very much ;-)
