Santos san
I want to measure th etime period between two signals ( rst and cs )
my FPGA is connected to push button switch (sw) to initialize the counter with zero and also connected to 7 segment to display the results
My design uses a counter signal ranges fro 0 to 1048580
my code is below :
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
Entity COUNT is
port(
sw : in std_logic ;
rst : in std_logic ;
clk : in std_logic ;
cs : in std_logic ;
a : out std_logic;
b : out std_logic;
c : out std_logic;
d : out std_logic ;
e : out std_logic ;
f : out std_logic ;
g : out std_logic
end COUNT;
architecture a of COUNT is
signal counter : integer range 0 to 1048580;
signal decide : std_logic_vector(1 downto 0);
begin
stsprocess(clk,sw,decide)
begin
if clk='1' and clk'event then
if sw = '0' then
decide <= "00" ;
else
case decide is
when "00" =>
counter <= 0 ;
a <= '0' ; --------------- H
b <= '1' ;
c <= '1' ;
d <= '0' ;
e <= '1' ;
f <= '1' ;
g <= '1' ;
decide <= "01" ;
when "01" =>
if ( rst = '1' and cs = '1' ) then
decide <= "10" ;
else
decide <= "01";
end if;
when "10" =>
if ( rst = '1' and cs = '0' ) then
decide <= "11" ;
elsif ( rst = '1' and cs = '1' ) then
if (counter >1048576 ) then
counter <= counter ;
else
counter <= counter +1 ;
end if ;
else
-- U
a <= '0' ;
b <= '1' ;
c <= '1' ;
d <= '1' ;
e <= '1' ;
f <= '1' ;
g <= '0' ;
End if ;
when "11" =>
if (counter <= 104857 and counter > 0)then -- 0
a <= '1' ;
b <= '1' ;
c <= '1' ;
d <= '1' ;
e <= '1' ;
f <= '1' ;
g <= '0' ;
elsif (counter <= 209715 and counter > 104857 )then -- 1
a <= '0' ;
b <= '1' ;
c <= '1' ;
d <= '0' ;
e <= '0' ;
f <= '0' ;
g <= '0' ;
elsif (counter <= 314572 and counter > 209715)then -- 2
a <= '1' ;
b <= '1' ;
c <= '0' ;
d <= '1' ;
e <= '1' ;
f <= '0' ;
g <= '1' ;
elsif (counter <= 419430 and counter > 314572 )then -- 3
a <= '1' ;
b <= '1' ;
c <= '1' ;
d <= '1' ;
e <= '0' ;
f <= '0' ;
g <= '1' ;
elsif (counter <= 524288 and counter > 419430)then -- 4
a <= '0' ;
b <= '1' ;
c <= '1' ;
d <= '0' ;
e <= '0' ;
f <= '1' ;
g <= '1' ;
elsif (counter <= 629145 and counter > 524288 )then -- 5
a <= '1' ;
b <= '0' ;
c <= '1' ;
d <= '1' ;
e <= '0' ;
f <= '1' ;
g <= '1' ;
elsif (counter <= 734003 and counter > 629145 )then -- 6
a <= '1' ;
b <= '0' ;
c <= '1' ;
d <= '1' ;
e <= '1' ;
f <= '1' ;
g <= '1' ;
elsif (counter <= 838860 and counter > 734003 )then -- 7
a <= '1' ;
b <= '1' ;
c <= '1' ;
d <= '0' ;
e <= '0' ;
f <= '0' ;
g <= '0' ;
elsif (counter <= 943718 and counter > 838860 )then -- 8
a <= '1' ;
b <= '1' ;
c <= '1' ;
d <= '1' ;
e <= '1' ;
f <= '1' ;
g <= '1' ;
elsif (counter <= 1048576 and counter >943718 )then -- 9
a <= '1' ;
b <= '1' ;
c <= '1' ;
d <= '1' ;
e <= '0' ;
f <= '1' ;
g <= '1' ;
else -- E
a <= '1' ;
b <= '0' ;
c <= '0' ;
d <= '1' ;
e <= '1' ;
f <= '1' ;
g <= '1' ;
end if;
when others => -- U
a <= '0' ;
b <= '1' ;
c <= '1' ;
d <= '1' ;
e <= '1' ;
f <= '1' ;
g <= '0' ;
end case;
end if ;
end if;
end process;
end;
Can any body test this code and tell my why it didn't work
I have attached the discription graph and 7 segment indications !!
my code is below :
library IEEE;
Entity COUNT is
port(
sw : in std_logic ;
cs : in std_logic ;
a : out std_logic;
b : out std_logic;
c : out std_logic;
d : out std_logic ;
e : out std_logic ;
f : out std_logic ;
g : out std_logic
end COUNT;
begin
begin
if sw = '0' then
decide <= "00" ;
else
case decide is
when "00" =>
counter <= 0 ;
b <= '1' ;
c <= '1' ;
d <= '0' ;
e <= '1' ;
f <= '1' ;
g <= '1' ;
decide <= "01" ;
when "01" =>
decide <= "10" ;
else
decide <= "01";
end if;
when "10" =>
decide <= "11" ;
else
end if ;
else
-- U
a <= '0' ;
b <= '1' ;
c <= '1' ;
d <= '1' ;
e <= '1' ;
f <= '1' ;
g <= '0' ;
End if ;
when "11" =>
a <= '1' ;
b <= '1' ;
c <= '1' ;
d <= '1' ;
e <= '1' ;
f <= '1' ;
g <= '0' ;
a <= '0' ;
b <= '1' ;
c <= '1' ;
d <= '0' ;
e <= '0' ;
f <= '0' ;
g <= '0' ;
a <= '1' ;
b <= '1' ;
c <= '0' ;
d <= '1' ;
e <= '1' ;
f <= '0' ;
g <= '1' ;
a <= '1' ;
b <= '1' ;
c <= '1' ;
d <= '1' ;
e <= '0' ;
f <= '0' ;
g <= '1' ;
a <= '0' ;
b <= '1' ;
c <= '1' ;
d <= '0' ;
e <= '0' ;
f <= '1' ;
g <= '1' ;
a <= '1' ;
b <= '0' ;
c <= '1' ;
d <= '1' ;
e <= '0' ;
f <= '1' ;
g <= '1' ;
a <= '1' ;
b <= '0' ;
c <= '1' ;
d <= '1' ;
e <= '1' ;
f <= '1' ;
g <= '1' ;
a <= '1' ;
b <= '1' ;
c <= '1' ;
d <= '0' ;
e <= '0' ;
f <= '0' ;
g <= '0' ;
a <= '1' ;
b <= '1' ;
c <= '1' ;
d <= '1' ;
e <= '1' ;
f <= '1' ;
g <= '1' ;
a <= '1' ;
b <= '1' ;
c <= '1' ;
d <= '1' ;
e <= '0' ;
f <= '1' ;
g <= '1' ;
else -- E
a <= '1' ;
b <= '0' ;
c <= '0' ;
d <= '1' ;
e <= '1' ;
f <= '1' ;
g <= '1' ;
end if;
when others => -- U
a <= '0' ;
b <= '1' ;
c <= '1' ;
d <= '1' ;
e <= '1' ;
f <= '1' ;
g <= '0' ;
end case;
end if ;
end if;
end process;
end;
