Looking for 4 channel lights dimmer
mareharpoon
Newbie level 2
Newbie level 2
hello
I m looking 4ch (or more) light dimmer for 220v lights with microcontroller.
Where can I found schematics and sorce code
Best regards
4 ch lights dimmer
Look in the Microchip web site on the X-10 ( in App. Notes ) and also look for AN958.
www.microchip.com
If you found my answer useful, click on the button that says Helped me. ( NO points will be taken from you! )
Good luck.
4 ch lights dimmer
Hi gidimiz,
How is home appliances controlled in X10 home automation system....I mean to say does it uses solid state relay, electromagnetic relay or something else to switch the appliances??
Thanks
4 ch lights dimmer
4 ch lights dimmer
Ah....very nice link!!
Re: 4 ch lights dimmer
Have a look at the Microchip document
There you will see how the X-10 works, and even more.... For example how you can run your MCU without a transformer!
Good luck.
