LINT WAIVER's syntax for SoC flow.
raghava_edaboard
Newbie level 1
Newbie level 1
Bangalore
HI all,
I want to prepare a waiver file for LINT flow.
Could you please give me syntax for this and let me know how to include in LINT flow.
Thanks
HI
Exact requirement is below.
Say suppose we got particular error message "all the bits of signal dout are not uses".
As a designer we know it is expected and can be waived off, then how can I write waiver for this error message.
Regards,
Raghavendra
Hi Raghavendra,
U can do it by following command :
waive -msg "all the bits of signal dout are not uses"
or if u want a particular rule to waive
write
waive -rule "RULE-NAME".
Regards,
Sohil
" Say suppose we got particular error message "all the bits of signal dout are not uses".
As a designer we know it is expected and can be waived off, then how can I write waiver for this error message."
Hi ,
In log file there will be a rule name ahead of this line "all the bits of signal dout are not uses" you mentioned.Just write that in below syntax to waive it off.
