cyboman
Member level 4
i'm somewhat new to digital design. i'm using ISE WebPack 11.1 and a Nexys 2 board (Spartan 3E FPGA) to learn more about digital design and FPGAs in general.
the WebPack can generate a test fixture (at least initial version of it) for a given module.
below is the initial block it generated for me
i can't understand what global reset is? why is it generated?
for the small designs i wrote i used to write the test fixtures as follows:
but then i removed the global reset and wrote the code as follows and my test bench still worked:
i would appreciate the explanation of what the global reset is. is it needed for the test fixture to settle down or it is just something the generator inserts?
thanks in advance
initial begin
// Initialize Inputs
clk = 0;
reset = 0;
// Wait 100 ns for global reset to finish
#100;
// Add stimulus here
end
initial begin
clk = 0;
reset = 0;
#100;
// reset
reset = 1'b1;
// wait for reset to finish
#20;
reset = 1'b0;
end
initial begin
clk = 0;
reset = 0;
// reset
reset = 1'b1;
#20;
reset = 1'b0;
end
thanks in advance
