Hi ,guys
Recently I have met a problem with 48V power supply.
I used a TL431 as regulator.
The figure blow is the schematic.I simullated in Multisim.It worked well.
But after I soldered the components on board, the output gave a big ripple(200mV Vp-p,4Hz).
I used an oscilloscope and detected a big pulse with the same frequency as the ripple at Q1-Base(As following figure shows).
Is this a self-oscillation?
How to fix it?
Thanks a lot.
I think the latch you used at the gate of Q1 is of very high current gain. Try to increase the resistnace R3 (470 ohm) to a 1 kohm or so. and use a capacitor of 1 pF at the gate (sorry base) of Q1.
