Spoerle
Junior Member level 2
- Joined
- Mar 22, 2022
- Messages
- 22
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 292
They are repairing an older lab instrument and I am stuck on one part.
In the device there are two boards fitted with 74HCxxx logic, 5V power supply.
On first PCB is output any 74HC logic output, symbolically represented by U10A. it goes to port 2 of that mysterious Q3 component in the SOT23 case . On port 1 is 5V and on port 3 is 200 ohm resistor and connector SMA for coax line.
On second board is SMA connector, 200ooh resistor a any 74HC logic input.
I would expect that Q3 is some kind of transistor that increases the output current of the 74HC in order to charge the parasitic capacitance of C28, i.e. the coaxial cable.
The problem is when I measure the terminals the only diode I can find is the diode between terminals 2 and 3 Anode on 3.
I'm not the wiser
NPN, PNP or JFET have two measurable PN junctions, MOSFT can have one but not between G and D.
Can't think of what it could be?
I'm not the wiser
