drewcrew
Newbie level 6
Hello,
I'm trying to make a boost converter that will have a digital pwm control feedback that will be implemented with microcontroller. However, before I get started, I'm having a hard time figuring out the switching frequency.
My main requirements are Vin = 12 V; Vout = 30Volts.
In order to find the switching frequency, I used the formula:
Vo/Vi = Tsw/Toff = 1/(1-D).
Tsw I use comes from the ntype mosfet..IRFP60n. I got 55ns from the datasheet.
When I solve this for Tsw, I get Tsw = 1.38E-7.
From this, I get fsw = 1/Tsw = 7 Mhz.
I'm used to seeing boost converter frequencies in the kHz. I'm afraid this is too high and will result in losses. I also know there is the RHP zero issue but I'm not sure if that frequency will affect it and I'm not particularly sure how to calculate that.
I appreciate your help in advance.
Thanks
Thanks
