Ip core generator in xilink 12.1
saqib49
Newbie level 6
Newbie level 6
I am using xilink 12.1 .. IP (CORE Generator & Architecture Wizard) not appearing in file type menu...
Can any one guide me about procedure to access ip in xilink 12.1
Does the Coregen show up under the start menu in the Xilinx ISE folder. I don't have ISE 12.1 installed (that's pretty old), but 13.2 was under
All Programs->Xilinx ISE Design Suite 13.2->ISE Design Tools->64-bit Tools->CORE Generator
If it doesn't exist in the Xilinx start menu folder perhaps the Xilinx ISE installation was not done correctly.
Also there should be a ISE_DS\ISE\coregen directory in the Xilinx install directory or somewhere similar.
I just checked , core generator is there,and also opening perfectly.. every thing is fine.. still option not appearing in source type menu
Seems to me you have an installation problem, I've never seen it missing from the menu before.
LaTeX Commands Quick-Menu:
