Internal pull up/pull down in FPGA's
kiranec2004
Newbie level 1
Hi
If for any IO's internal pullup/pulldown is defined inside FPGA then can we remove the externally mounted resistors for pullup/pulldown on the PCB ???
Thanks in advance
Hello,
That's right, you can remove your extrenal resisters if you are using the internal pullup/pulldown options in your FPGA. Also, some FPGAs allow on-chip terminating to terminate RF transmission lines. This is used for high-speed memorys like DDR SDRAM, for example.
Best regards,
magixD
