Induced gate noise and thermal noise in ADS
amir88
bandarabbas
Is there any way to display separately induced gate noise and thermal noise of a transistor in Agilent ADS ?
Thanks in advance
amir88
bandarabbas
Activate "Noise Contribution".
can you explain it more precisely?
I checked calculate noise in S-parameters. But in dispaly data there are nf(2) and NFmin and I donot konw how to display gate noise and thermal noise, separately.
pancho_hideboo
Advanced Member level 5
Real Homeless
There is no answer easier than this.
"Noise Contribution" is provided even in S-parameter analysis.
If you would like to observe noise voltage at specific nodes, use AC-Noise Analysis where "Noise Contribution" is also provided as same as SP-Analysis and HB-Analysis.
amir88
bandarabbas
finally I found out where this noise contributers are,so there is no easier answer :grin:. but which parameter indicates gate noise and thermal noise? I have activate it in sort by name, but there's no direct name or parameter that indicates gate noise or thermal noise.
amir88
bandarabbas
But it's not clear, and I have to extract noise factor and display it by using MATLAB.Thanks any way.
