enemra
Junior Member level 1
I have two questions in the image that I have attached. the image is of a power amplifier board.
Thank you
- The output of the amplifier has irregular copper trace with different length until the output SMA, which I pointed as (1). Doesn't this impact the impedance of the trace?
- What is the use of two vertical traces before the output SMA, which I pointed as (2)?
Thank you
