You should be able to email your manufacturer regarding layer stackups or even just mention the controlled impedance and tolerance in the manufacturing notes and have them adjust thicknesses as needed.
If you want to continue the calculator route could you give us an idea what parameters you're struggling with?
There won't necessarily be a standard since the impedance will change with trace and layer thickness, dielectric material, number of layers and all sorts of other things that can vary between manufacturers.
