promach
I have the following IMPACT log with JTAG
Can't open /dev/parport0: No such file or directory
Can't open /dev/parport1: No such file or directory
Can't open /dev/parport2: No such file or directory
Can't open /dev/parport3: No such file or directory
GUI --- Auto connect to cable...
// *** BATCH CMD : setCable -port auto
AutoDetecting cable. Please wait.
*** WARNING ***: When port is set to auto detect mode, cable speed is set to default 6 MHz regardless of explicit arguments supplied for setting the baud rates
PROGRESS_START - Starting Operation.
Using windrvr6 driver.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
File version of /opt/Xilinx/14.7/ISE_DS/ISE/bin/lin64/xusbdfwu.hex = 1030.
File version of /usr/share/xusbdfwu.hex = 1030.
libusb-driver.so version: 2021-04-18 11:44:26.
Cable connection failed.
Connecting to cable (Parallel Port - parport0).
LPT1 Base Address set from env variable = 0.
LPT base address = 0000h.
LPT1 Ecp Address set from env variable = 400.
ECP base address = 0400h.
LPT port is already in use. rc = FFFFFFFFh
Connecting to cable (Parallel Port - parport1).
LPT2 Base Address set from env variable = 10.
LPT base address = 0010h.
LPT2 Ecp Address set from env variable = 410.
ECP base address = 0410h.
Connecting to cable (Parallel Port - parport2).
LPT3 Base Address set from env variable = 20.
LPT base address = 0020h.
LPT3 Ecp Address set from env variable = 420.
ECP base address = 0420h.
Connecting to cable (Parallel Port - parport3).
LPT4 Base Address set from env variable = 30.
LPT base address = 0030h.
LPT4 Ecp Address set from env variable = 430.
ECP base address = 0430h.
PROGRESS_END - End Operation.
Elapsed time = 2 sec.
Cable autodetection failed.
WARNING:iMPACT:923 - Can not find cable, check cable setup !
