Richard29
Member level 1
Hi all,
I am trying to interact with the ICAP controller on the Virtex5 and I am not really successful so far. The primitive for
the ICAP controller looks as follows:
ICAP_VIRTEX5_I : ICAP_VIRTEX5
generic map (
ICAP_WIDTH => "X32")
port map (
clk => clk,
ce => icap_ce,
write => icap_we,
i => icap_datain,
busy => icap_busy,
o => icap_dataout);
Checking the synthesis report, it shows that one ICAP controller has been instantiated.The next step is to simply write the synchronisation word (0xAA995566) to icap_datain with icap_ce = 0 and icap_we = 0. Normally when receiving the SYNC word icap_out should change to 0xDF, however, in my case icap_out remains at 0x9f which indicates that no SYNC word has been received by the ICAP controller. I tried all different combinations of the synchronisation word, so litte and big endian as well as bit swapping.
Is there anything else I have to consider when trying to interact with the ICAP component. Do I have to specify any constraints in the UCF file. Alternatively, do I need to specify some specific options when generating the bitstream?
Any comments that could solve my problem would be highly appreciated!
generic map (
port map (
clk => clk,
ce => icap_ce,
write => icap_we,
i => icap_datain,
busy => icap_busy,
o => icap_dataout);
