kishore2k4
Full Member level 5
- Joined
- Jun 17, 2006
- Messages
- 291
- Helped
- 44
- Reputation
- 88
- Reaction score
- 11
- Trophy points
- 1,298
- Location
- Middle Earth
- Activity points
- 3,295
lasi layout
I am just getting started with IC Layout and design. I looked around for something that is free and is in use. The following are what I found.
-> LASI
-> Alliance CAD
-> Magic
Here is my view on them and I want your opinion. The first one(LASI) is the only windows based CAD tool I found that actually is used a lot by academia and some industrial projects too. Its usage and design are very much clearly explained in the book "CMOS Layout Design and Simulation by Baker,Li,Boyce". The book is excellent reference for IC layout.
The latter two run on Linux. Alliance CAD is really awesome. It has got plethora of tools with it and very easy to install. It has got its own standard cell library and automatic place and route tools. Oh did I mention that it can only do digital designs. compile,synthesize,place & route. If you need analog design tools check out Cairo etc. They are also available on Alliance CAD website.
It seems that Magic is extensively used in some US universities(USC) but I couldn't get rpm files for it. I installed Linux just to run these linux based EDA tools and I am not sure if I can install from source files and stuff.
Bottom Line, If you are just getting started or only into Digital Design go for Alliance CAD and for Custom Layout try LASI or Magic. I am not sure about Magic but LASI interface needs somewhat "getting used to".
I really appreciate your opinions and corrections.
cheers,
kishore.
-> LASI
-> Alliance CAD
-> Magic
cheers,
kishore.
