snp33
Newbie level 6
Hey all
I am using ic compiler for the first time so i dont know if I am doing something wrong or if my plib file is erroneous. This is what happens when I try to create a library using my plib file:
icc_shell> create_mw_lib -plib ../CORX90GPSVT.plib newlib
Wrote the 'CORX90GPSVT' library to '/home/samuel/aes/run/tech.pdb' successfully.
WARNING : **** No technology information!
Warning: Preset gridResolution to 10, please check. (MWLIBP-017)
Start to load technology file .pdbin_dummy.tf.
Technology file .pdbin_dummy.tf has been loaded successfully.
Warning: No time_conversion_factor has been specified for the physical library. It is set to default '1e+3' . (MWLIBP-030)
Warning: No power_conversion_factor has been specified for the physical library. It is set to default '1e+6' . (MWLIBP-030)
Warning: No voltage_conversion_factor has been specified for the physical library. It is set to default '1e+6' . (MWLIBP-030)
Cannot perform requested operation.
Done.
Warning: No reference library is offered. So preferredrouting direction can't be set. (MWUI-216)
After these messages the tool creates a library but it contains no physical data at all... therefore i cant perform placement, routing, etc...
ANy toughts?
Done.
ANy toughts?
