alejandrodaniel
Newbie level 3
as the title.
If I link 16f767 an external EEPROM 24C64 works fine.
in the SCL/SDA line pull-up resistors 2K2.
the code:
But if I want to send a data to pic_slave and it should write in it's internal EEPROM it do incorrect write.
This is the code:
This is the code of the slave 16F876A:
the end of trasmizione data i find myself with the internal eeprom of 16F876A written randomly (both data and position)
Excuse my English
the code:
''''''''''''''' SUBPROCEDURAS ''''''''''''''''''''''''''''''''''''''''''''''''''
SUB PROCEDURE Escribe_Eeprom(DIM wAddress AS WORD,DIM Dato AS WORD)
I2C_Start() 'Envia señal de inicio I2C
I2C_Wr($A6) 'Envia byte a la EEPROM externa
I2C_Wr(HI(wAddress)) 'Envia el valor alto address de la EEPROM)
I2C_Wr(LO(wAddress)) 'Envia el valor bajo address de la EEPROM)
I2C_Wr(Dato) 'Envia el valor del dato
I2C_Stop() 'Envia señal de parada I2C
END SUB
''''''''''''''' INICIA '''''''''''''''''''''''''''''''''''''''''''''''''''''''''
Main:
ADCON1=%10001111 'PORTA.0/1/2/3 analogicas,resto digital.PORTB digital,justificado a derecha + Vref
TRISA=%000000 'PORTA como output
TRISB=%00000000 'PORTB como output
TRISC=%00011000 'Puertas PORTC.3 y PORTC.4 son input
PORTA=%000000 'Setaje PORTA
PORTB=%00000000 'Setaje PORTB
PORTC=%00000000 'Setaje PORTC
Address_mem=0 'Inicializo la variable del Address
vValor=0 'Inicializo la variable del dato
I2C_Init(312500) 'SSPADD=((FOSC/CLOCK_I2C)/4)-1
Envia_Slave:
Escribe_Eeprom(Address_mem,vValor)
INC(vValor)
INC(Address_mem)
GOTO Envia_Slave
ELSE
GOTO Envia_Slave
END IF
END.
This is the code:
SUB PROCEDURE Escribe_Slave(DIM wID_Add AS WORD,DIM Dato AS WORD)
I2C_Wr(wID_Add) 'Envia byte ID_Address al slave
END SUB
Main:
Envia_Slave:
IF I2C_Is_Idle THEN
Escribe_Slave($A4,vValor)
INC(vValor)
Delay_ms(25) 'Tiempo espera Slave escriba en memoria
GOTO Envia_Slave
ELSE
GOTO Envia_Slave
END IF
END.
PROGRAM Control_mot_16F876A
'***************************** VARIABLES ***************************************
DIM Address_mem,Clear_buffer,Rx_Buffer,Tx_Data AS BYTE
'**************************** SUB PROCEDURAS ***********************************
SUB PROCEDURE Interrupt()
IF TESTBIT(PIR1,SSPIF)=1 THEN 'I2C slave subroutine
IF TESTBIT(SSPSTAT,R_W)=1 THEN 'Lee el dato pedido del master
SSPBUF=Tx_Data 'Agregar codigo
SETBIT(SSPCON,CKP) 'Libera el clock
GOTO EXIT_I2C
END IF
IF TESTBIT(SSPSTAT,BF)=0 THEN 'Todo hecho
GOTO EXIT_I2C
END IF
IF TESTBIT(SSPSTAT,D_A)=1 THEN 'Dato,no ID_Address
Rx_Buffer=SSPBUF 'Lee el dato del master
Eeprom_Write(Address_mem,Rx_Buffer) 'Lo escribe en memoria
Delay_ms(10) 'Espera que termine de escribir en memoria
INC(Address_mem) 'Incrementa el valor del address
GOTO EXIT_I2C
END IF
END IF
EXIT_I2C:
CLEARBIT(PIR1,SSPIF) 'Limpia el flag del interrupt
Clear_buffer=SSPBUF 'Limpio el buffer
END SUB
'***************************** INICIA ******************************************
Main:
ADCON1=%10000010 'Cinco puertas analogicas
SSPADD=$A4 'Setaje ID_Address
SSPCON=%00110110 'Setaje SSPCON --- ALTERNATIVA %00111110
SSPCON2=%00000000 'Setaje SSPCON2 --- Habilita GCEN y RCEN %10001000
PIE1=%00001000 'Habilita SSP interrupts
INTCON=%11000000 'Habilita GIE y PEIE
SSPSTAT=%00000000 'Desabilito SSPSTAT
PIR1.SSPIF=0 'Limpia el flag del interrupt
Address_mem=0
WHILE true
WEND
END.
Excuse my English
