swgchlry
Member level 4
When I synthesize a design, one port "reg[7:0] data" is an inout port, should I set the output delay or input delay or both? I only set the output delay on "data" in the top design,and then the SynDC indicated that some end-points in the sub design had not been set the max delay constraint. Does it aroused by the unenough constratins? If not, what's the problem?
thx
thx
