pranavam
Junior Member level 1
Plz help...
1) Can u tell how to use LPMs in the following code efficiently without loosing the logic..
The device i selected is Altera cyclone II 2c20 F484c7 fpga....
And am not using any embedded memory blocks in the FPGA ( M4K)... Thus after compilation LEs consumed exceeds the available no. of LEs.. ( Because memory requirement in the program consumes LES instead of M4k..)
2) One more thing... Am a newbie in HDL design.. I dont know the standard writing styles.. Plz tell me how to optimize this code without loosing the logic
module final_4(strobe,data_inp,HEX0,HEX1,HEX2,HEX3,clk);
//output [9:0] LEDR;
//reg [9:0] LEDR;
input [6:0] data_inp;
input strobe;
input clk;
output [0:6] HEX0;
reg [0:6] HEX0=7'b1111111;
output [0:6] HEX1;
reg [0:6] HEX1=7'b1111111;
output [0:6] HEX2;
output [0:6] HEX3;
assign HEX2=7'b1111111;
assign HEX3=7'b1111111;
reg [20:0] le2 ;
reg [34:0] le1;
reg [2:0] rr;
reg [34:0] reg_train [0:77];
reg [13:0] luptable [0:35];
reg [5:0] addr_lup;
reg [6:0] addr;
reg [34:0] a [0:2];
reg [34:0] b [0:2];
reg [34:0] c [0:2];
reg [34:0] d [0:2];
reg [34:0] e [0:2];
reg [34:0] f [0:2];
reg [34:0] g [0:2];
reg [34:0] h [0:2];
reg [34:0] i [0:2];
reg [34:0] j [0:2];
reg [34:0] k [0:2];
reg [34:0] l [0:2];
reg [34:0] m [0:2];
reg [34:0] n [0:2];
reg [34:0] o [0:2];
reg [34:0] p [0:2];
reg [34:0] q [0:2];
reg [34:0] r [0:2];
reg [34:0] s [0:2];
reg [34:0] t [0:2];
reg [34:0] u [0:2];
reg [34:0] v [0:2];
reg [34:0] w [0:2];
reg [34:0] x [0:2];
reg [34:0] y [0:2];
reg [34:0] z [0:2];
reg [1:0] aaa;
reg [1:0] bbb;
reg [1:0] ccc;
reg [1:0] ddd;
reg [1:0] eee;
reg [1:0] fff;
reg [1:0] ggg;
reg [1:0] hhh;
reg [1:0] iii;
reg [1:0] jjj;
reg [1:0] kkk;
reg [1:0] lll;
reg [1:0] mmm;
reg [1:0] nnn;
reg [1:0] ooo;
reg [1:0] ppp;
reg [1:0] qqq;
reg [1:0] rrr;
reg [1:0] sss;
reg [1:0] ttt;
reg [1:0] uuu;
reg [1:0] vvv;
reg [1:0] www;
reg [1:0] xxx;
reg [1:0] yyy;
reg [1:0] zzz;
/*reg [5:0]s1;
reg [5:0]s2;
reg [5:0]s3;
reg [5:0]s4;*/
reg [5:0] sum [0:25];
reg [5:0] suma[0:2];
reg [5:0] sumb[0:2];
reg [5:0] sumc[0:2];
reg [5:0] sumd[0:2];
reg [5:0] sume[0:2];
reg [5:0] sumf[0:2];
reg [5:0] sumg[0:2];
reg [5:0] sumh[0:2];
reg [5:0] sumi[0:2];
reg [5:0] sumj[0:2];
reg [5:0] sumk[0:2];
reg [5:0] suml[0:2];
reg [5:0] summ[0:2];
reg [5:0] sumn[0:2];
reg [5:0] sumo[0:2];
reg [5:0] sump[0:2];
reg [5:0] sumq[0:2];
reg [5:0] sumr[0:2];
reg [5:0] sums[0:2];
reg [5:0] sumt[0:2];
reg [5:0] sumu[0:2];
reg [5:0] sumv[0:2];
reg [5:0] sumw[0:2];
reg [5:0] sumx[0:2];
reg [5:0] sumy[0:2];
reg [5:0] sumz[0:2];
reg [13:0] su [0:25];
reg ss;
integer jj=0;
integer mm=0;
integer ll=0;
always @(posedge strobe)
begin
case (rr)
3'b000:
begin le1[6:0] = data_inp;
le2[6:0] = le1[6:0];
rr=rr+3'b001;
end
3'b001:
begin le1[13:7] = data_inp;
le2[13:7] = le1[13:7];
rr=rr+3'b001;
mm=mm+1;
if (mm < 36)
begin
rr=3'b000;
addr_lup=addr_lup+6'b000001;
luptable[addr_lup]={le1[6:0],le1[13:7]};
end
end
3'b010:
begin
rr=rr+3'b001;
le1[20:14] = data_inp;
le2[20:14] = le1[20:14];
if( le2[13:0]==14'b11111111111111)
begin
ll=1;
addr=addr+le2[20:14];
case(le2[20:14])
7'b0000000 : begin
aaa=aaa+2'b01;
addr=addr+aaa;
// LEDR[9]=1'b1;
end
7'b0000011 : begin
bbb=bbb+2'b01;
addr=addr+bbb;
// LEDR[8]=1'b1;
end
7'b0000110 : begin
ccc=ccc+2'b01;
addr=addr+ccc;
// LEDR[7]=1'b1;
end
7'b0001001 : begin
ddd=ddd+2'b01;
addr=addr+ddd;
// LEDR[6]=1'b1;
end
7'b0001100 : begin
eee=eee+2'b01;
addr=addr+eee;
// LEDR[5]=1'b1;
end
7'b0001111 : begin
fff=fff+2'b01;
addr=addr+fff;
// LEDR[4]=1'b1;
end
7'b0010010 : begin
ggg=ggg+2'b01;
addr=addr+ggg;
end
7'b0010101 : begin
hhh=hhh+2'b01;
addr=addr+hhh;
end
7'b0011000 : begin
iii=iii+2'b01;
addr=addr+iii;
end
7'b0011011 : begin
jjj=jjj+2'b01;
addr=addr+jjj;
end
7'b0011110 : begin
kkk=kkk+2'b01;
addr=addr+kkk;
end
7'b0100001 : begin
lll=lll+2'b01;
addr=addr+lll;
end
7'b0100100 : begin
mmm=mmm+2'b01;
addr=addr+mmm;
end
7'b0100111 : begin
nnn=nnn+2'b01;
addr=addr+nnn;
end
7'b0101010 : begin
ooo=ooo+2'b01;
addr=addr+ooo;
end
7'b0101101 : begin
ppp=ppp+2'b01;
addr=addr+ppp;
end
7'b0110000 : begin
qqq=qqq+2'b01;
addr=addr+qqq;
end
7'b0110011 : begin
rrr=rrr+2'b01;
addr=addr+rrr;
end
7'b0110110 : begin
sss=sss+2'b01;
addr=addr+sss;
end
7'b0111001 : begin
ttt=ttt+2'b01;
addr=addr+ttt;
end
7'b0111100 : begin
uuu=uuu+2'b01;
addr=addr+uuu;
end
7'b0111111 : begin
vvv=vvv+2'b01;
addr=addr+vvv;
end
7'b1000010 : begin
www=www+2'b01;
addr=addr+www;
end
7'b1000101 : begin
xxx=xxx+2'b01;
addr=addr+xxx;
end
7'b1001000 : begin
yyy=yyy+2'b01;
addr=addr+yyy;
end
7'b1001011 : begin
zzz=zzz+2'b01;
addr=addr+zzz;
end
endcase
rr=3'b000;
end
le2=21'b0;
end
3'b011:
begin le1[27:21] = data_inp;
rr=rr+3'b001; end
3'b100:
begin le1[34:28] = data_inp;
rr=rr+3'b001; end
default: begin
if(ll==1)
begin reg_train[addr]=le1;
ll=0;
end
rr=3'b000;
// LEDR<=reg_train[1] [34:26] ;
jj=jj+1;
if (jj>=27)
addr=0;
else
begin
addr=addr+7'b0000011;
end
end
endcase
end
//assign LEDR= le1[9:0];
integer ii;
integer kk;
integer hh;
integer larg;
integer classify;
always @(posedge clk)
begin
sum[0]=6'b111111;
sum[1]=6'b111111;
sum[2]=6'b111111;
sum[3]=6'b111111;
sum[4]=6'b111111;
sum[5]=6'b111111;
sum[6]=6'b111111;
sum[7]=6'b111111;
sum[8]=6'b111111;
sum[9]=6'b111111;
sum[10]=6'b111111;
sum[11]=6'b111111;
sum[12]=6'b111111;
sum[13]=6'b111111;
sum[14]=6'b111111;
sum[15]=6'b111111;
sum[16]=6'b111111;
sum[17]=6'b111111;
sum[18]=6'b111111;
sum[19]=6'b111111;
sum[20]=6'b111111;
sum[21]=6'b111111;
sum[22]=6'b111111;
sum[23]=6'b111111;
sum[24]=6'b111111;
sum[25]=6'b111111;
for(ii=0;ii<=2;ii=ii+1)
begin
suma[ii]=6'b000000;
sumb[ii]=6'b000000;
sumc[ii]=6'b000000;
sumd[ii]=6'b000000;
sume[ii]=6'b000000;
sumf[ii]=6'b000000;
sumg[ii]=6'b000000;
sumh[ii]=6'b000000;
sumi[ii]=6'b000000;
sumj[ii]=6'b000000;
sumk[ii]=6'b000000;
suml[ii]=6'b000000;
summ[ii]=6'b000000;
sumn[ii]=6'b000000;
sumo[ii]=6'b000000;
sump[ii]=6'b000000;
sumq[ii]=6'b000000;
sumr[ii]=6'b000000;
sums[ii]=6'b000000;
sumt[ii]=6'b000000;
sumu[ii]=6'b000000;
sumv[ii]=6'b000000;
sumw[ii]=6'b000000;
sumx[ii]=6'b000000;
sumy[ii]=6'b000000;
sumz[ii]=6'b000000;
end
for (ii=0;ii<=2;ii=ii+1)
begin
if(reg_train[ii]!=35'b0)
a[ii]=le1^reg_train[ii];
else
a[ii]=35'b1111111111111111111111111111111111;
end
for (ii=3;ii<6;ii=ii+1)
begin
b[ii-3]=le1^reg_train[ii];
else
b[ii-3]=35'b1111111111111111111111111111111111;
end
for (ii=6;ii<9;ii=ii+1)
begin
c[ii-6]=le1^reg_train[ii];
else
c[ii-6]=35'b1111111111111111111111111111111111;
end
for (ii=9;ii<12;ii=ii+1)
begin
d[ii-9]=le1^reg_train[ii];
else
d[ii-9]=35'b1111111111111111111111111111111111;
end
for (ii=12;ii<15;ii=ii+1)
begin
e[ii-12]=le1^reg_train[ii];
else
e[ii-12]=35'b1111111111111111111111111111111111;
end
for (ii=15;ii<18;ii=ii+1)
begin
f[ii-15]=le1^reg_train[ii];
else
f[ii-15]=35'b1111111111111111111111111111111111;
end
for (ii=18;ii<21;ii=ii+1)
begin
g[ii-18]=le1^reg_train[ii];
else
g[ii-18]=35'b1111111111111111111111111111111111;
end
for (ii=21;ii<24;ii=ii+1)
begin
h[ii-21]=le1^reg_train[ii];
else
h[ii-21]=35'b1111111111111111111111111111111111;
end
for (ii=24;ii<27;ii=ii+1)
begin
i[ii-24]=le1^reg_train[ii];
else
i[ii-24]=35'b1111111111111111111111111111111111;
end
for (ii=27;ii<30;ii=ii+1)
begin
j[ii-27]=le1^reg_train[ii];
else
j[ii-27]=35'b1111111111111111111111111111111111;
end
for (ii=30;ii<33;ii=ii+1)
begin
k[ii-30]=le1^reg_train[ii];
else
k[ii-30]=35'b1111111111111111111111111111111111;
end
for (ii=33;ii<36;ii=ii+1)
begin
l[ii-33]=le1^reg_train[ii];
else
l[ii-33]=35'b1111111111111111111111111111111111;
end
for (ii=36;ii<39;ii=ii+1)
begin
m[ii-36]=le1^reg_train[ii];
else
m[ii-36]=35'b1111111111111111111111111111111111;
end
for (ii=39;ii<42;ii=ii+1)
begin
n[ii-39]=le1^reg_train[ii];
else
n[ii-39]=35'b1111111111111111111111111111111111;
end
for (ii=42;ii<45;ii=ii+1)
begin
o[ii-42]=le1^reg_train[ii];
else
o[ii-42]=35'b1111111111111111111111111111111111;
end
for (ii=45;ii<48;ii=ii+1)
begin
p[ii-45]=le1^reg_train[ii];
else
p[ii-45]=35'b1111111111111111111111111111111111;
end
for (ii=48;ii<51;ii=ii+1)
begin
q[ii-48]=le1^reg_train[ii];
else
q[ii-48]=35'b1111111111111111111111111111111111;
end
for (ii=51;ii<54;ii=ii+1)
begin
r[ii-51]=le1^reg_train[ii];
else
r[ii-51]=35'b1111111111111111111111111111111111;
end
for (ii=54;ii<57;ii=ii+1)
begin
s[ii-54]=le1^reg_train[ii];
else
s[ii-54]=35'b1111111111111111111111111111111111;
end
for (ii=57;ii<60;ii=ii+1)
begin
t[ii-57]=le1^reg_train[ii];
else
t[ii-57]=35'b1111111111111111111111111111111111;
end
for (ii=60;ii<63;ii=ii+1)
begin
u[ii-60]=le1^reg_train[ii];
else
u[ii-60]=35'b1111111111111111111111111111111111;
end
for (ii=63;ii<66;ii=ii+1)
begin
v[ii-63]=le1^reg_train[ii];
else
v[ii-63]=35'b1111111111111111111111111111111111;
end
for (ii=66;ii<69;ii=ii+1)
begin
w[ii-66]=le1^reg_train[ii];
else
w[ii-66]=35'b1111111111111111111111111111111111;
end
for (ii=69;ii<72;ii=ii+1)
begin
x[ii-69]=le1^reg_train[ii];
else
x[ii-69]=35'b1111111111111111111111111111111111;
end
for (ii=72;ii<75;ii=ii+1)
begin
y[ii-72]=le1^reg_train[ii];
else
y[ii-72]=35'b1111111111111111111111111111111111;
end
for (ii=75;ii<78;ii=ii+1)
begin
z[ii-75]=le1^reg_train[ii];
else
z[ii-75]=35'b1111111111111111111111111111111111;
end
for (hh=0;hh<=2;hh=hh+1)
begin
for (ii=0;ii<=34;ii=ii+1)
begin
suma[hh]=suma[hh]+a[hh] [ii];
sumb[hh]=sumb[hh]+b[hh] [ii];
sumc[hh]=sumc[hh]+c[hh] [ii];
sumd[hh]=sumd[hh]+d[hh] [ii];
sume[hh]=sume[hh]+e[hh] [ii];
sumf[hh]=sumf[hh]+f[hh] [ii];
sumg[hh]=sumg[hh]+g[hh] [ii];
sumh[hh]=sumh[hh]+h[hh] [ii];
sumi[hh]=sumi[hh]+i[hh] [ii];
sumj[hh]=sumj[hh]+j[hh] [ii];
sumk[hh]=sumk[hh]+k[hh] [ii];
suml[hh]=suml[hh]+l[hh] [ii];
summ[hh]=summ[hh]+m[hh] [ii];
sumn[hh]=sumn[hh]+n[hh] [ii];
sumo[hh]=sumo[hh]+o[hh] [ii];
sump[hh]=sump[hh]+p[hh] [ii];
sumq[hh]=sumq[hh]+q[hh] [ii];
sumr[hh]=sumr[hh]+r[hh] [ii];
sums[hh]=sums[hh]+s[hh] [ii];
sumt[hh]=sumt[hh]+t[hh] [ii];
sumu[hh]=sumu[hh]+u[hh] [ii];
sumv[hh]=sumv[hh]+v[hh] [ii];
sumw[hh]=sumw[hh]+w[hh] [ii];
sumx[hh]=sumx[hh]+x[hh] [ii];
sumy[hh]=sumy[hh]+y[hh] [ii];
sumz[hh]=sumz[hh]+z[hh] [ii];
end
end
for (kk=0;kk<=2;kk=kk+1)
begin
if(suma[kk] < sum[0])
sum[0]=suma[kk];
if(sumb[kk] < sum[1])
sum[1]=sumb[kk];
if(sumc[kk] < sum[2])
sum[2]=sumc[kk];
if(sumd[kk] < sum[3])
sum[3]=sumd[kk];
if(sume[kk] < sum[4])
sum[4]=sume[kk];
if(sumf[kk] < sum[5])
sum[5]=sumf[kk];
if(sumg[kk] < sum[6])
sum[6]=sumg[kk];
if(sumh[kk] < sum[7])
sum[7]=sumh[kk];
if(sumi[kk] < sum[8])
sum[8]=sumi[kk];
if(sumj[kk] < sum[9])
sum[9]=sumj[kk];
if(sumk[kk] < sum[10])
sum[10]=sumk[kk];
if(suml[kk] < sum[11])
sum[11]=suml[kk];
if(summ[kk] < sum[12])
sum[12]=summ[kk];
if(sumn[kk] < sum[13])
sum[13]=sumn[kk];
if(sumo[kk] < sum[14])
sum[14]=sumo[kk];
if(sump[kk] < sum[15])
sum[15]=sump[kk];
if(sumq[kk] < sum[16])
sum[16]=sumq[kk];
if(sumr[kk] < sum[17])
sum[17]=sumr[kk];
if(sums[kk] < sum[18])
sum[18]=sums[kk];
if(sumt[kk] < sum[19])
sum[19]=sumt[kk];
if(sumu[kk] < sum[20])
sum[20]=sumu[kk];
if(sumv[kk] < sum[21])
sum[21]=sumv[kk];
if(sumw[kk] < sum[22])
sum[22]=sumw[kk];
if(sumx[kk] < sum[23])
sum[23]=sumx[kk];
if(sumy[kk] < sum[24])
sum[24]=sumy[kk];
if(sumz[kk] < sum[25])
sum[25]=sumz[kk];
end
luptable[0]=14'b11111111111111;
su[0]=luptable[sum[0]];
su[1]=luptable[sum[1]];
su[2]=luptable[sum[2]];
su[3]=luptable[sum[3]];
su[4]=luptable[sum[4]];
su[5]=luptable[sum[5]];
su[6]=luptable[sum[6]];
su[7]=luptable[sum[7]];
su[8]=luptable[sum[8]];
su[9]=luptable[sum[9]];
su[10]=luptable[sum[10]];
su[11]=luptable[sum[11]];
su[12]=luptable[sum[12]];
su[13]=luptable[sum[13]];
su[14]=luptable[sum[14]];
su[15]=luptable[sum[15]];
su[16]=luptable[sum[16]];
su[17]=luptable[sum[17]];
su[18]=luptable[sum[18]];
su[19]=luptable[sum[19]];
su[20]=luptable[sum[20]];
su[21]=luptable[sum[21]];
su[22]=luptable[sum[22]];
su[23]=luptable[sum[23]];
su[24]=luptable[sum[24]];
su[25]=luptable[sum[25]];
larg=14'b00000000;
for (kk=0;kk<26;kk=kk+1)
if(su[kk] > larg)
begin
larg=su[kk];
classify=kk;
end
case(classify)
0: begin
HEX0=7'b1001111;
HEX1=7'b1111111;
end
1: begin
HEX0=7'b0010010;
HEX1=7'b1111111;
end
2: begin
HEX0=7'b0000110;
HEX1=7'b1111111;
end
3: begin
HEX0=7'b1101100;
HEX1=7'b1111111;
end
4: begin
HEX0=7'b0100100;
HEX1=7'b1111111;
end
5: begin
HEX0=7'b0100000;
HEX1=7'b1111111;
end
6: begin
HEX0=7'b0001111;
HEX1=7'b1111111;
end
7: begin
HEX0=7'b0000000;
HEX1=7'b1111111;
end
8: begin
HEX0=7'b0001100;
HEX1=7'b1111111;
end
9: begin
HEX0=7'b0000001;
HEX1=7'b1001111;
end
10: begin
HEX0=7'b1001111;
HEX1=7'b1001111;
end
11: begin
HEX0=7'b0010010;
HEX1=7'b1001111;
end
12: begin
HEX0=7'b0000110;
HEX1=7'b1001111;
end
13: begin
HEX0=7'b1101100;
HEX1=7'b1001111;
end
14: begin
HEX0=7'b0100100;
HEX1=7'b1001111;
end
15: begin
HEX0=7'b0100000;
HEX1=7'b1001111;
end
16: begin
HEX0=7'b0001111;
HEX1=7'b1001111;
end
17: begin
HEX0=7'b0000000;
HEX1=7'b1001111;
end
18: begin
HEX0=7'b0001100;
HEX1=7'b1001111;
end
19: begin
HEX0=7'b0000001;
HEX1=7'b0010010;
end
20: begin
HEX0=7'b1001111;
HEX1=7'b0010010;
end
21: begin
HEX0=7'b0010010;
HEX1=7'b0010010;
end
22: begin
HEX0=7'b0000110;
HEX1=7'b0010010;
end
23: begin
HEX0=7'b1101100;
HEX1=7'b0010010;
end
24: begin
HEX0=7'b0100100;
HEX1=7'b0010010;
end
25: begin
HEX0=7'b0100000;
HEX1=7'b0010010;
end
default:
begin
HEX0=7'b0000000;
HEX1=7'b0000000;
end
endcase
end
//assign LEDR[9:0]=luptable[1] [9:0] ;
//assign trainop1=reg_train[0];
//assign trainop2=reg_train[1];
endmodule
//reg [9:0] LEDR;
input strobe;
input clk;
output [0:6] HEX0;
output [0:6] HEX1;
output [0:6] HEX2;
output [0:6] HEX3;
reg [20:0] le2 ;
reg [34:0] le1;
reg [2:0] rr;
reg [5:0] addr_lup;
reg [6:0] addr;
reg [34:0] a [0:2];
reg [34:0] b [0:2];
reg [34:0] c [0:2];
reg [34:0] d [0:2];
reg [34:0] e [0:2];
reg [34:0] f [0:2];
reg [34:0] g [0:2];
reg [34:0] h [0:2];
reg [34:0] i [0:2];
reg [34:0] j [0:2];
reg [34:0] k [0:2];
reg [34:0] l [0:2];
reg [34:0] m [0:2];
reg [34:0] n [0:2];
reg [34:0] o [0:2];
reg [34:0] p [0:2];
reg [34:0] q [0:2];
reg [34:0] r [0:2];
reg [34:0] s [0:2];
reg [34:0] t [0:2];
reg [34:0] u [0:2];
reg [34:0] v [0:2];
reg [34:0] w [0:2];
reg [34:0] x [0:2];
reg [34:0] y [0:2];
reg [34:0] z [0:2];
reg [1:0] aaa;
reg [1:0] bbb;
reg [1:0] ccc;
reg [1:0] ddd;
reg [1:0] eee;
reg [1:0] fff;
reg [1:0] ggg;
reg [1:0] hhh;
reg [1:0] iii;
reg [1:0] jjj;
reg [1:0] kkk;
reg [1:0] lll;
reg [1:0] mmm;
reg [1:0] nnn;
reg [1:0] ooo;
reg [1:0] ppp;
reg [1:0] qqq;
reg [1:0] rrr;
reg [1:0] sss;
reg [1:0] ttt;
reg [1:0] uuu;
reg [1:0] vvv;
reg [1:0] www;
reg [1:0] xxx;
reg [1:0] yyy;
reg [1:0] zzz;
/*reg [5:0]s1;
reg [5:0]s2;
reg [5:0]s3;
reg [5:0]s4;*/
reg ss;
integer jj=0;
integer mm=0;
integer ll=0;
begin
case (rr)
3'b000:
rr=rr+3'b001;
end
3'b001:
rr=rr+3'b001;
mm=mm+1;
if (mm < 36)
begin
rr=3'b000;
end
end
3'b010:
begin
rr=rr+3'b001;
begin
ll=1;
case(le2[20:14])
7'b0000000 : begin
aaa=aaa+2'b01;
addr=addr+aaa;
// LEDR[9]=1'b1;
end
7'b0000011 : begin
bbb=bbb+2'b01;
addr=addr+bbb;
// LEDR[8]=1'b1;
end
7'b0000110 : begin
ccc=ccc+2'b01;
addr=addr+ccc;
// LEDR[7]=1'b1;
end
7'b0001001 : begin
ddd=ddd+2'b01;
addr=addr+ddd;
// LEDR[6]=1'b1;
end
7'b0001100 : begin
eee=eee+2'b01;
addr=addr+eee;
// LEDR[5]=1'b1;
end
7'b0001111 : begin
fff=fff+2'b01;
addr=addr+fff;
// LEDR[4]=1'b1;
end
7'b0010010 : begin
ggg=ggg+2'b01;
addr=addr+ggg;
end
7'b0010101 : begin
hhh=hhh+2'b01;
addr=addr+hhh;
end
7'b0011000 : begin
iii=iii+2'b01;
addr=addr+iii;
end
7'b0011011 : begin
jjj=jjj+2'b01;
addr=addr+jjj;
end
7'b0011110 : begin
kkk=kkk+2'b01;
addr=addr+kkk;
end
7'b0100001 : begin
lll=lll+2'b01;
addr=addr+lll;
end
7'b0100100 : begin
mmm=mmm+2'b01;
addr=addr+mmm;
end
7'b0100111 : begin
nnn=nnn+2'b01;
addr=addr+nnn;
end
7'b0101010 : begin
ooo=ooo+2'b01;
addr=addr+ooo;
end
7'b0101101 : begin
ppp=ppp+2'b01;
addr=addr+ppp;
end
7'b0110000 : begin
qqq=qqq+2'b01;
addr=addr+qqq;
end
7'b0110011 : begin
rrr=rrr+2'b01;
addr=addr+rrr;
end
7'b0110110 : begin
sss=sss+2'b01;
addr=addr+sss;
end
7'b0111001 : begin
ttt=ttt+2'b01;
addr=addr+ttt;
end
7'b0111100 : begin
uuu=uuu+2'b01;
addr=addr+uuu;
end
7'b0111111 : begin
vvv=vvv+2'b01;
addr=addr+vvv;
end
7'b1000010 : begin
www=www+2'b01;
addr=addr+www;
end
7'b1000101 : begin
xxx=xxx+2'b01;
addr=addr+xxx;
end
7'b1001000 : begin
yyy=yyy+2'b01;
addr=addr+yyy;
end
7'b1001011 : begin
zzz=zzz+2'b01;
addr=addr+zzz;
end
endcase
rr=3'b000;
end
le2=21'b0;
end
3'b011:
rr=rr+3'b001; end
3'b100:
rr=rr+3'b001; end
default: begin
if(ll==1)
ll=0;
end
rr=3'b000;
jj=jj+1;
if (jj>=27)
addr=0;
else
begin
end
end
endcase
end
integer ii;
integer kk;
integer hh;
integer larg;
integer classify;
begin
sum[0]=6'b111111;
sum[1]=6'b111111;
sum[2]=6'b111111;
sum[3]=6'b111111;
sum[4]=6'b111111;
sum[5]=6'b111111;
sum[6]=6'b111111;
sum[7]=6'b111111;
sum[8]=6'b111111;
sum[9]=6'b111111;
sum[10]=6'b111111;
sum[11]=6'b111111;
sum[12]=6'b111111;
sum[13]=6'b111111;
sum[14]=6'b111111;
sum[15]=6'b111111;
sum[16]=6'b111111;
sum[17]=6'b111111;
sum[18]=6'b111111;
sum[19]=6'b111111;
sum[20]=6'b111111;
sum[21]=6'b111111;
sum[22]=6'b111111;
sum[23]=6'b111111;
sum[24]=6'b111111;
sum[25]=6'b111111;
begin
suma[ii]=6'b000000;
sumb[ii]=6'b000000;
sumc[ii]=6'b000000;
sumd[ii]=6'b000000;
sume[ii]=6'b000000;
sumf[ii]=6'b000000;
sumg[ii]=6'b000000;
sumh[ii]=6'b000000;
sumi[ii]=6'b000000;
sumj[ii]=6'b000000;
sumk[ii]=6'b000000;
suml[ii]=6'b000000;
summ[ii]=6'b000000;
sumn[ii]=6'b000000;
sumo[ii]=6'b000000;
sump[ii]=6'b000000;
sumq[ii]=6'b000000;
sumr[ii]=6'b000000;
sums[ii]=6'b000000;
sumt[ii]=6'b000000;
sumu[ii]=6'b000000;
sumv[ii]=6'b000000;
sumw[ii]=6'b000000;
sumx[ii]=6'b000000;
sumy[ii]=6'b000000;
sumz[ii]=6'b000000;
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
else
end
begin
begin
end
end
begin
sum[0]=suma[kk];
sum[1]=sumb[kk];
sum[2]=sumc[kk];
sum[3]=sumd[kk];
sum[4]=sume[kk];
sum[5]=sumf[kk];
sum[6]=sumg[kk];
sum[7]=sumh[kk];
sum[8]=sumi[kk];
sum[9]=sumj[kk];
sum[10]=sumk[kk];
sum[11]=suml[kk];
sum[12]=summ[kk];
sum[13]=sumn[kk];
sum[14]=sumo[kk];
sum[15]=sump[kk];
sum[16]=sumq[kk];
sum[17]=sumr[kk];
sum[18]=sums[kk];
sum[19]=sumt[kk];
sum[20]=sumu[kk];
sum[21]=sumv[kk];
sum[22]=sumw[kk];
sum[23]=sumx[kk];
sum[24]=sumy[kk];
sum[25]=sumz[kk];
end
larg=14'b00000000;
if(su[kk] > larg)
begin
larg=su[kk];
classify=kk;
end
case(classify)
0: begin
HEX0=7'b1001111;
HEX1=7'b1111111;
end
1: begin
HEX0=7'b0010010;
HEX1=7'b1111111;
end
2: begin
HEX0=7'b0000110;
HEX1=7'b1111111;
end
3: begin
HEX0=7'b1101100;
HEX1=7'b1111111;
end
4: begin
HEX0=7'b0100100;
HEX1=7'b1111111;
end
5: begin
HEX0=7'b0100000;
HEX1=7'b1111111;
end
6: begin
HEX0=7'b0001111;
HEX1=7'b1111111;
end
7: begin
HEX0=7'b0000000;
HEX1=7'b1111111;
end
8: begin
HEX0=7'b0001100;
HEX1=7'b1111111;
end
9: begin
HEX0=7'b0000001;
HEX1=7'b1001111;
end
10: begin
HEX0=7'b1001111;
HEX1=7'b1001111;
end
11: begin
HEX0=7'b0010010;
HEX1=7'b1001111;
end
12: begin
HEX0=7'b0000110;
HEX1=7'b1001111;
end
13: begin
HEX0=7'b1101100;
HEX1=7'b1001111;
end
14: begin
HEX0=7'b0100100;
HEX1=7'b1001111;
end
15: begin
HEX0=7'b0100000;
HEX1=7'b1001111;
end
16: begin
HEX0=7'b0001111;
HEX1=7'b1001111;
end
17: begin
HEX0=7'b0000000;
HEX1=7'b1001111;
end
18: begin
HEX0=7'b0001100;
HEX1=7'b1001111;
end
19: begin
HEX0=7'b0000001;
HEX1=7'b0010010;
end
20: begin
HEX0=7'b1001111;
HEX1=7'b0010010;
end
21: begin
HEX0=7'b0010010;
HEX1=7'b0010010;
end
22: begin
HEX0=7'b0000110;
HEX1=7'b0010010;
end
23: begin
HEX0=7'b1101100;
HEX1=7'b0010010;
end
24: begin
HEX0=7'b0100100;
HEX1=7'b0010010;
end
25: begin
HEX0=7'b0100000;
HEX1=7'b0010010;
end
default:
begin
HEX0=7'b0000000;
HEX1=7'b0000000;
end
endcase
end
endmodule
