javi
Junior Member level 1
I have an hard IP ( in Netlist form) with the timing information setup/hold to clock , clock to output delay , pad to pad delay and the maximum operating frequency. The given information looks likes a data-sheet report or say overall IP interface timing budget.
Now , when I integrate it into my top module with dont_touch options , how do I specify my top module clock timing constraints while taking considerations of the hard IP timings.
1. How to consider the setup_clock timing information of the IP. Will it affect the top module clock period specification? .
2. Similarly which portion (AT or RT ) of the top module timing analysis is affected by the clock to output delay of the IP.
I hope this is common flow query irrespective of the tools being used.
Is their any good document for any ASIC flow specifies IP FLOW integration / Timing constraints aspects.
Thanks,
Javi
Thanks,
Javi
