wjx197733 said:Hi, MRFGUY, can you tell me detail: how to use JTEG to test CPLD?
xuruquan said:If you can download program to it,you can use small program whitch you can be sure be right to test . if all the pin can work , the chip is ok
Is thsi Altera only?YUV said:Please, stusy carefully next info about STAPL language.
You can use it for testing and even whole board through JTAG. Also, you can include a bitstream into JAM file to programm your device. I believe that will be useful for you.
Embedded Programming With Jam STAPL h**p://www.@ltera.com/support/devices/tools/jam/embedded/tls-jam-embedded.html
Jam Programming & Test Language Specification h**p://www.@ltera.com/literature/jam/jamspec1_1.pdf
JAM software is here: http://www.@ltera.com/support/software/download/programming/jam/jam-index.jsp
AN 122: Using Jam STAPL for ISP & ICR via an Embedded Processorh**p://www.@ltera.com/literature/an/an122.pdf
gliss said:Is thsi @ltera only?
