Aug 18, 2018 #1 L liletian Full Member level 6 Joined Mar 5, 2008 Messages 337 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,298 Activity points 3,790 How to reverse the signal order when create bus in irun results? HI all How to reverse the signal order when you create bus? As you can see from the attachement, the signal order is from 0 to 7, I would like to have the bus from 7 to 0 instead. Thank you, Attachments att.png 97.8 KB · Views: 83
