I used Tetramax to generate test patterns for a full adder design. After finish, I showed the first pattern, and receive the following figure. I really dont understand how to read it. I thought a pattern contains a set of inputs. But here I see 3 bits for one input ????.
Check set pindata variable. U will find various options for it. The three bits which you are referring depends on this command. The three bits refer to preclock, clock and postclock data. U can find this information in the tetramax document.
