How to Queue-up simulations in HFSS 14/15 ?
muhammad idrees
Hi, everyone,
I have a question about the HFSS v15 that how to queue-up simulations in HFSS 15? so that the simulations run after one an other. Is it possible to ask HFSS 15 to simulate several projects one by one? :?::?::?:
thanks;
Go to Tools->Options->General options
Check "queue all simulations" in the page of "analysis options"
You can also manage them by clicking the "Q" icon just under the menu bar.
you told me to the above procedure for the purpose mentioned eailer.
I have done the same job it is right for a single project under the same name. The problem is that if i want to Queue-up different projects under the different names then what would be the procedure? And the under the sane application opened. i.e if i open the my first_project in HFSS and run it at the same time i open another project under the name Second_Project and want to run (queue-up) it in the first project window then what would be done.
Is it possible?
:thinker::thinker::thinker:
The method you told me work well but for only one project name and Q-up simulations only by changing some parameters in the same design but i want the above method. :-(
