How to make the dirll with oblong or oval shape in Pads
hoang_quy
Junior Member level 1
routing oval shape
I design my project using POWER PCB and Pads2005 .But I don't how to make the dirll with oblong or oval shape .The default is round shape .Please help me !
Edit padstack, there you can define the length of slotted hole for pads. Also you can define it plated or non plated hole.
If you are not able to get that thendefine it as slot & specify the slot dimension in drill layer or in other layer. Do not forget to pass this layer to PCB manufacturer.
Good Luck
Thank you very much .I design successful .
