How to improve current mirror error (Iin & Iout) ?
jiachang
Newbie level 1
Newbie level 1
i used cascode current mirror to generate around 238nA constant current for cap. charging.
But i always got Iout= 233nA to 242nA varation during charging period.
How can i keep the Iout constant?
Thanks
venkateshr
Member level 3
Member level 3
what is current mirrors-errors
Hi jiachang ,
It is very good to use to have cascode mirror for this precise replication .even though it is a feeble difference due to diff in VDS between actual and mirrored (or finite op impedance ) it may be noteworthy in some cases. I think cascode with more stacks(>2) can multiply the op. resistance thereby bringing down the difference
p.s :If supply voltage is a constraint .WIDE SWING CASCODE will help u .
Added after 4 minutes:
Jiachang ,
You can use longer L(also W by same factor) but maintaining the same W/L ratio so that op resistance is increased .
holddreams
Full Member level 6
Full Member level 6
Shanghai
you can refer this paper -----"DESIGN AND OPTIMIZATION OF A HIGH PSRR CMOS BANDGAP VOLTAGE REFERENCE".
Try.
tbksandeep
Junior Member level 2
USA(Texas)
what is a current mirror-error
jichang u can vary w/l ratio first and see it.one important suggestion is use active loads.since ur loking for a current of such a low value i would suggest active loads..did u use diff amplifier at the input?if u have not done so do it and try it.u might get better results.
