How to dump FSDB file in Modelsim_Linux,with Debussy_NT
freelysolo07
Hi, all
I have modelsim_linux, and debussy_NT, i use verilog,
How can i dump fsdb file?
Thanks very much
Added after 11 minutes:
If possible, can every give me the related PLI files provided by Debussy_Linux?
Because the only PLI_WINNT files in the Debussy_NT install dir
Thanks
chandhramohan
Member level 2
Hi ,
I don't know about WINNT ,but for LINUX / Solaris you can find the PLI files in the installation path . Link your PLI tab files to your simulator .The linking varies with simulator .
Then you can dump using ,
initial
begin
$fsdbdumpfile(file_name);
$fsdbdumpvars(level,instance_path);
end
Regards
Chandhramohan
mm_zhou1983
Newbie level 2
do you want to watch the waveform using debussy?
this way :
you can dump the VCD file use Modelsim
then use the nWave to open the VCD file
nWave can change the VCD file the fsdb format automatically
