How to disable some clock gating check in SDC ?
lx1019
Hi all ,
When doing STA using PT. It reports some unnecessary violations of the **clock_gating_default** group.
From the PT manual, I find out by using the PT command "set_disable_clock_gating_check cells" could disable these unnecessary checking.
But how to disable them in SDC file? So that the backend tool don't care these unnecessary checking.
Take a AND gate as a clock gating cell for example. When I use "set_false_path -to [get_cells AND]" ,
PT gives warning that the AND cell is not a valid endpoint.
Thanks!
clock gating checks are not unnecessary checks...
Your design should not have any clock gating violations.
you can disable clock gating checks using set_disable_timing also...
You can ask PT to dump only REG2REG/REG2OUT/IN2REG paths using -group option in report_timing...
Hi all ,
Thanks!
Yes, the clock gating is not unnecessary.
But some cells that PT takes as a clock gating cell is not the real clock gating cells we want.
For example, a MUX that select several clocks to output for debug purpose.
I don't want to disable all the clock gating checks, but only the unnecessary.
Now my solution is using "set_false_path -through clk_gating_cell" .
Is there any other better solution?
why can't you try "set_disable_clock_gating_check <<cell name/pinname>>
