How to create Castellated SMT pads using Altium Designer
udhay_cit
Full Member level 6
Dear friends,
I want to create SMD mountable daughter boards for my PCB'S. I am using altium designer & want to know how to create Castellated SMT pads using altium...
Is there any special setting available to make this kind of pads?
Regards
Udhay
mstrghettorigg
Junior Member level 1
Can you not just use a plated hole with pad and place the center on the board edge? I'm not sure, but I don't think you'll be able to make a half plated hole.
Then again Altium has suprised me before with some of their stuff.
I don't use Altium enough to know for sure, but I know in other CAD you would just make it as you would a plated through hole and center it on the edge. I would put a note on the fab drawing for your intentions or contact them to ask about what note you should put in there.
Hope it helps
Anonymous_Ricky
Advanced Member level 2
India
Better ask you fabricator as how he needs the information.
You can do it whichever way it is understandable to him.
backdoor_
Member level 2
Just place full vias so the board outline goes thru the center of the vias. No need for any extra note for the fab house.
They will fabricate the PCB exactly the way you design (what they see on the gerbers) - place the vias and route them so only half of vias are left.
