Jul 27, 2010 #1 V Vamsi115 Junior Member level 2 Joined Sep 8, 2009 Messages 21 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Activity points 1,402 Hi all, I want to convert a .PCB file in P-CAD to .asc the ASCII form. Any suggestions PLZ!! Thanks, Vamsi.
Jul 27, 2010 #2 B B.G. Junior Member level 3 Joined Jul 16, 2009 Messages 25 Helped 6 Reputation 12 Reaction score 6 Trophy points 1,283 Activity points 1,388 Hi. 1. File=>Save as... 2. In file type window select "ASCII Files". 3. Save. (File extention will be .pcb too) Good luck!
Jul 27, 2010 #3 V Vamsi115 Junior Member level 2 Joined Sep 8, 2009 Messages 21 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Activity points 1,402 B.G, Thanks for the reply. The thing is my customer wanted it in .asc format only can i rename it to .asc and send since it is converted to ASCII format.. Vamsi
Jul 27, 2010 #4 B B.G. Junior Member level 3 Joined Jul 16, 2009 Messages 25 Helped 6 Reputation 12 Reaction score 6 Trophy points 1,283 Activity points 1,388 I cannot tell, as I don't know, why converting to .asc format is needed And I don't know what program uses it format.
Jul 27, 2010 #5 cyberrat Advanced Member level 3 Joined Jun 19, 2001 Messages 902 Helped 87 Reputation 174 Reaction score 43 Trophy points 1,308 Location In the sewers of the U.K. Activity points 5,900 What is your customer planning on doing with it? If they are going to import it into another CAD program then tell us which one? ASCII is ASCII whatever the file extension.
Jul 28, 2010 #6 V Vamsi115 Junior Member level 2 Joined Sep 8, 2009 Messages 21 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Activity points 1,402 They wanted to import it to PADS layout. Vamsi
Jul 28, 2010 #7 B B.G. Junior Member level 3 Joined Jul 16, 2009 Messages 25 Helped 6 Reputation 12 Reaction score 6 Trophy points 1,283 Activity points 1,388 Sorry, but PADS ASCII and PCAD ASCII are not compatible.
Jul 28, 2010 #8 V Vamsi115 Junior Member level 2 Joined Sep 8, 2009 Messages 21 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Activity points 1,402 Thanks for all your valuable suggestions.. I will sure reply if i can find any other way to do that. Thanks again, Vamsi.
Feb 2, 2011 #9 N newnewey Newbie level 1 Joined Feb 2, 2011 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,284 Vamsi115, Were you successful in converting Pcad layout to PADS layout? If you did it, did you have any errors? Thank you. Newey
