How to compare signal in Verdi
Renjie
Newbie level 5
Is it possible to compare two signals in the same fsdb waveform in verdi ?
For example, A[31:0] output value from 0, 1, 2, 3 ...1000, and this happens between time 0 and 10us.
B[31:0] output similar value from 0, 1, 2, 3 ... 1000, and this happens between 100us and 110us.
In Verdi, is there anyway we can compare these two to see if there would be any data mismatch in between?
Thanks.
Have never used Verdi.
As an alternate approach, you can write out the o/p of A and B to two different files along at the same time and then use the file Compare Plugin of Notepad++ to compare the file contents.
