diego.fan
Member level 3
Hi, all
I'm designing a differential ring oscillator. I want to simulate the influence of supply voltage noise on phase noise.
I use "Number of noise/freq pairs" in vdc to generate noise, as Figure shows. I compare the phase noise with noise (Number of noise =2) and without noise (Number of noise=0).
Figure shows the results. My question is: because this is a differential oscillator, The noise from VDD should be a common mode signal. I think phase noise should have no difference, as the differential type rejects the common mode noise. But why is phase noise still different? The red curve in Figure is phase noise without vdd noise and the blue one is the one with vdd noise.
Thanks!
Thanks!
