how to browse a 3D pcb_board ?
wangpengddl
Newbie level 3
hi:
what's tools a u used in allegro pcb design when u want to browse a 3d board?
regards[/quote]
Hi you !!
I faced this problem in the past !!
I try to search on internet the software which support PCB and 3D ! but i failed !!
So i solve this problem by using Autodesk Inventor, It can draw 3D components very easy !! and then you place them on your board to make template !!
I thinks you can use another soft : solid works, machenical ,...
Good luck
I think the correct way is to use a EDA that has a module that let you visualize your board in 3D. Check Cadstard 3D, etc. I haven't use any.
thank you. I have download pro-e tools,only need set the height of component in allegro or pro-e.
