Dear all,
If I describe modulo operation in verilog, such as "a <= b % c",how can the synthesis tool help me to turn this into hardware? I think it is pretty hard for implementation if c is not equal to the power of 2......
Most synthesis tools will complain exactly as you predicted, with an error message that says "second operand must be a power of two".
Next step is to read the vendor's libraries manual to see if they provide an optimized division module.
Tony Tao,
UR solution asks for 1 integer divider , 1 multiplier and then a subtraction operation to be done in one clock . .. It will be extermely difficult to meet timing with such arrangement . The soultion is by bit manipulation using barel shifters but for that the operand has to be power of 2 ! ... this is more viable from timing closure point of view . UR comments ...
Most basic synthesis tools (Xilinx ISE, Design Compiler, etc.) will not automatically synthesize % or DIVIDE (/).
Synopsys sells an enhanced arithmetic library (DesignWare Foundation) for the Design_Compiler product. If you have the DW-Foundation (DWF) license, then you can directly synthesize "a = b % c" -- the DWF license will create a hardware implementation using combinational logic.
I think Cadence PKS/Buildgates also has similar capability, but I need to check.
If you don't have access to either of these tools, then you'll have to come up with your own implementation.
