rajesh13
Full Member level 2
- Joined
- Jul 7, 2004
- Messages
- 125
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,298
- Location
- Greater Noida, India
- Activity points
- 1,209
DoctorProf said:If the process allows it then there should be ground rules that determine how it can be used. I would check with the process guys or foundry to see if the process you are using allows AAB. If it does they should point you to the ground rules you need to follow to get reliable devices.
andy2000a said:I have one question .. I friend use umc 0.18um process
and put some CKT under PAD ..
then --> pad have pad_pilling problem .,,
