How does 4 pole, triple throw switch work?
zmanultra
Member level 2
Australia
im really confused about the operation of these kind of switched i need to use one because the toggle allows the user to choose between 3 modes of operation.
can some one explain the circuit for me, im i dont know how it works, i googled but didn’t help me...
:cry:
A.Anand Srinivasan
Advanced Member level 5
India
Re: 4 pole, triple throw
a 4 pole means that the input is from 4 terminals..... triple throw means that these 4 inputs can be connected to 3 output sets of 4 poles each.....
zmanultra
Member level 2
Australia
i dont understand what do you mean by :
"4 inputs can be connected to 3 output sets of 4 poles each....."
im so confused
A.Anand Srinivasan
India
the 4 input terminals contain a different input each.... and there a 3 sets of output which each have 4 output terminals.... these input terminals can be connected to any of these output set.....
zmanultra
Member level 2
Australia
you said....
do you mean
the 4 input terminals contain a different output each....
A.Anand Srinivasan
India
ya... it is just the way of looking that differs.....
these 4 terminals are the what are meant by the term 4 pole.....
zmanultra
Member level 2
Australia
how does it work? say i want to the first mode to be off (no power) the second mode to have power (signal A) , and the third mode to have power (signal B)
i dont know how to go on about it
i drew a pic for you to help me understand what will happen.
i really appreciate your help A.Anand :)
A.Anand Srinivasan
India
what you have drawn is a 4 pole double throw.... these 4 inputs A,B,C,D switch together and hence either E(i),F(i),G(i),H(i) will have power or E(ii),F(ii),G(ii),H(ii) will have power at any instant of time.... if you add a third terminal E(iii),F(iii),G(iii),H(iii) then it is 4 pole triple throw switch.....
are you able to understand it.....
    zmanultra
zmanultra
Member level 2
Australia
you know where u said that either E(i),F(i),G(i),H(i) will have power or E(ii),F(ii),G(ii),H(ii) will have power .....does that depend on what i feed the inputs?
and also, whats confusing me is the why the hell do e for example have two lines? can you explain that?
A.Anand Srinivasan
India
hey E(i) and E(ii) are connected to different circuits..... it wont be connected to the same place as you have drawn in the circuit.... whether E(i) gets power or E(ii) gets power depends on you i.e to which one you connect A,,.....
zmanultra
Member level 2
Australia
A.Anand thanx i understand now. i just needed time to sink in, i undestand 100% now :)
i wasnt looking at the actuall outputs off e f g h...
each set will give a different signal :D
