HOW DO I --- Run 2 Devices using one AC Adapter...???
kaanuki
Newbie level 2
Hello, All.
I am a converted computer nerd, whose last serious electronics project was in high school, 10 years ago - so, please bear with me.
I am creating a project where I am combining 2 completely seperate (off the shelf) electronics devices into one box, creating a sort of "ALL-IN-ONE" solution. As it stands, each of these devices is self powered, and comes with its own AC Adapters. I would like to create(have created) a power converting circuit board to allow me to run both devices using just 1 AC adapter. Here are the power specs(and my dilemna)...
Device #1: 12v / ~100mA
Device #2: 12v / ~500mA
What type of voltage and circuitry is called for here, and what other considerations are needed?. Any help or Guidance would be appreciated.
Thank you.
-Kaanuki-
You would need a 12V suply which can source current to both the devices. Since both the devices combined will at the max need 600mA, use a 12V adapter with 600mA supply capability or more, and connect both devices in parallel.
    kaanuki
Thanks for the reply, aryajur.
:D
-kaan-
