How can I find all the negedge trigged flip-flops.
wkong_zhu
Full Member level 3
How can i find all the negedge trigged flip-flops in the entire design.
Can I use synopsys to achieve it?
Or other tools?
cedance
Advanced Member level 2
Germany
truly, i couldnt understand ur question.. u mean u wanted to find all neg. edge triggered flipflops from a source code? or from a synthesised circuit? or what ? am i atleast near ur question?
/Am
tukken
Member level 2
you could find it in rtl code or netlist
diablo1222
Newbie level 6
Yes, you can use the design compiler. After read the desig and map, you can generate the report.
wkong_zhu
Full Member level 3
I mean that, The RTL code is not writen by me, but I will do synthesis, P&R, I want to set timing constrants on it, especially the negedge clock flip-flops make trouble, I want to find them all, then do analyze.
logicdrag
Junior Member level 1
Not depend on EDA tools!
you can write a script to check this issue.
eziggurat
Full Member level 6
I thought it was bad practice to use negative edge triggered flip-flops on a design.
pandora
Newbie level 5
put design to netlist
u could find it in netlist
spauls
DC will put invertor in clock for neg edge F/F
niuniu
Member level 5
just us 'grep' to fine the neg dff in verilog netlist.
